2005 v6 auto mustang
- Fastrider750
6 years 2 months ago #42128
by Fastrider750
2005 v6 auto mustang was created by Fastrider750
car died at traffic lite able to restart rough running made it home. ckd oil, water ok, copression good strong spark runs 3 sec then dies.no dtc,s no mil help?
6 years 2 months ago #42129
Replied by Tyler on topic 2005 v6 auto mustang
How's fuel pressure? Do you have access to scan data?
Will it run while adding alternative fuel?
- Fastrider750
6 years 2 months ago #42132
by Fastrider750
Replied by Fastrider750 on topic 2005 v6 auto mustang
fp test is next doesnt seem to have a schrader test point
6 years 2 months ago #42133
That's why I asked about scan data - the fuel rail pressure sensor will show up in scan data as an avaiable PID. May or may not show up on the Generic side with this model year.
If you keep your foot on the gas when three seconds comes around, can you keep it running?
Fastrider750 wrote: fp test is next doesnt seem to have a schrader test point
- Fastrider750
6 years 2 months ago #42137
by Fastrider750
no it bucks and acts just like running out of fuel .will swap ffilter in the morning and run a volume test in a soda bottle to verify fuel delivery if not then the old carb cleaner thru a vac port trick
- Fastrider750
6 years 2 months ago #42182
by Fastrider750
ffilter badly clogged, swap for new fp is 70psi, koeoff starts and runs 3 sec.then dies half throttle no change starts ,surges and dies like the fp shuts off on startup FPDM maybe?
- Fastrider750
6 years 2 months ago #42208
by Fastrider750
ok scan tool data is frp 70 initial settles to 45 koeo jumped the fp ground at fpdm for continuos fp run same thing starts and dies spark checker lit up until engine stops rotating this problem happened instantly no previous drivability issues
- Fastrider750
6 years 2 months ago #42209
by Fastrider750
also no dtc,s no mil either
6 years 2 months ago #42291
Replied by Noah on topic 2005 v6 auto mustang
Did you take a sample of the gasoline while changing the filter?
Thinking about bad/contaminated/wrong fuel.
Also, were you able to verify that fuel pressure remains in spec during the stall? I see key on engine off pressure readings in your post, but not the pressure in the rail while running and during the stall.
- Cheryl
- Thank you received: 215
6 years 2 months ago #42295
by Cheryl
Replied by Cheryl on topic 2005 v6 auto mustang
So it starts for 3 seconds and dies? If I were you I’d have a buddy start it up and see if ya can run it off of alternative fuel. That fuel rail pressure sensor might be lying as well with contamination in the fuel. So if possible t in a gauge.
The following user(s) said Thank You: Noah, Fastrider750
