equinox 2013 2.4 (lea)
- mikieb
- love to work on car
6 years 2 months ago #42039
by mikieb
mikieb
equinox 2013 2.4 (lea) was created by mikieb
I HAVE AN 2013 EQINOX 2.4L (LEA)ENGINE HEAD BEEN CHANGED DON'T KNOW WHO DONE THE OR Y I HAVE THE PROBLEM NOW
AT AN IDLE THE CAR RUNS BAD AFTER ABOUT AN HOUR INTO RUNNING JERKING BUCK IN PARK BOTH FUEL PRESSURE RISES UP HI SIDE GO TO @400*2000 FLUXTUATES LOW 57 TO 60 CODES ARE P0089 /P228D FUEL SENSOR PERFORMANCE THEY HAVE BEEN CHANGED DIDN'T FIX
HI PRESSURE FUEL PUMP BEEN CHANGED WAS LEAKING OIL EXTERNALYT AND THE FOLLOWER BECAUSE OF THE KEY WAY US MISSING DIDN'T FIX
THE INTAKE TIMING SAY 16 DEGEES AT IDLE AND WHEN IT ACTS UP IT FLUXTUATE TO 20 DEGREES UP/DOWN CHECK TIMING IT WAS IN TIME FROM WHAT I FOUND MY SPEC SAY TIMING SHOULD BE AT 0 DEGREE AT IDLE I'M THINKING TIMING SOME HOW NOT SURE WERE TO GO
mikieb
- Cheryl
- Thank you received: 215
6 years 2 months ago #42047
by Cheryl
Replied by Cheryl on topic equinox 2013 2.4 (lea)
Did this thing originally come with An lea engine??
- guafa
- Thank you received: 80
6 years 2 months ago #42050
by guafa
Replied by guafa on topic equinox 2013 2.4 (lea)
Hi,
You should post additional data at idle, so that we can find a direction.
Air flow, O2 readings, fuel trims, vacuum pressure, tps.
You can unplug VVT actuactors and check if idle improves.
- Ben
6 years 2 months ago #42051
by Ben
Replied by Ben on topic Re:equinox 2013 2.4 (lea)
Almost sounds like vvt system not getting enough oil pressure at idle when hot... Has the oil been changed ? May be a short term cure (run right for the first 1k miles) until oil thins, is valve train noisy at idle hot? Load some data clips cold idle and hot idle.
Sent from my Pixel 3a XL using Tapatalk
- mikieb
6 years 2 months ago #42060
by mikieb
mikieb
Replied by mikieb on topic equinox 2013 2.4 (lea)
Yes sir as for as I can tell all number match
mikieb
- mikieb
6 years 2 months ago #42061
by mikieb
mikieb
As you requested idle fuel pressure is 497 hi side low side 57 fuel trim is plus 3 to-3 moving good from.700 to .200 after about an hour it start to run bad has my posted reads at idle not driving (not being mean)engine fluctuations ba
mikieb
- mikieb
6 years 2 months ago #42062
by mikieb
mikieb
Replied by mikieb on topic Re:equinox 2013 2.4 (lea)
Valve train is not noise , oil been changed intake vvt solenoid been changed timing chain been changed and checked twice head been replaced don't know why used car dealer we deal with bought it like this
mikieb
- mikieb
6 years 2 months ago - 6 years 2 months ago #42093
by mikieb
mikieb
hello guys just what to say thank for your replies still not fixed when i get back to it my plain is to shut off thee intake vvt solenoid and is what it will do and to scope cam crk sensors . just some more info i had another equinox same yr. some engine i look at the info on that vehicle at idle and operating temp intake/ exhaust cam reads 0 degrees, intake and exhaust cam actuators read 0 degrees. if you have any question please e mail me at <span id="cloak738292293934be00b4f7ac8053e496b7">This email address is being protected from spambots. You need JavaScript enabled to view it.</span><s-cript type='text/j-avascript'>
document.getElementById('cloak738292293934be00b4f7ac8053e496b7').innerHTML = '';
var prefix = 'ma' + 'il' + 'to';
var path = 'hr' + 'ef' + '=';
var addy738292293934be00b4f7ac8053e496b7 = 'mile.benge' + '@';
addy738292293934be00b4f7ac8053e496b7 = addy738292293934be00b4f7ac8053e496b7 + 'gmail' + '.' + 'com';
var addy_text738292293934be00b4f7ac8053e496b7 = 'mile.benge' + '@' + 'gmail' + '.' + 'com';document.getElementById('cloak738292293934be00b4f7ac8053e496b7').innerHTML += '<a on-dragstart="return false;" ' + path + '\'' + prefix + ':' + addy738292293934be00b4f7ac8053e496b7 + '\'>'+addy_text738292293934be00b4f7ac8053e496b7+'<\/a>';
</script> or call 317-910-6753 if it's a loud or look me up on facebook or through here i may not answer right a way i have data when it's doing it i'm trying to down load it i have an i'm 608 trying to get the info to my computer mi used and block off for the intake solenoid when i blocked it off the timing degree was at 0 so i'm thinking the computer is controlling the timing just not sure what i'm missing everything ??
mikieb
Last edit: 6 years 2 months ago by mikieb. Reason: update on vehicle
- ed2
6 years 2 months ago #42164
by ed2
Replied by ed2 on topic equinox 2013 2.4 (lea)
I ran into a situation like this when i worked at the gm dealer. Make sure that all the cam caps are installed in the right place ( check letters or numbers I forget) . i had one drove me crazy. all were in wrong spot. made the line bore for the cam off enough that cam would not retard quickly ..... just saying ..... had it happen to me. made no noise . Just something to look at !
The following user(s) said Thank You: mikieb
- mikieb
6 years 1 month ago - 6 years 1 month ago #42495
by mikieb
mikieb
ok guys just an update on the equinox , it was sugestioned to check the cam cap so i did the cap was put back in the wright place as i can tell the arrows was facing the phaser gear(front ) number in order, so pulled some can cap off to look at oiling and of course they were scared up moderate so i pulled the intake cap off and found the seal missing,( dealer calls them 2 cam seals) , picture thanks ED2 for the advice and put me in the right direction
mikieb
Last edit: 6 years 1 month ago by mikieb.
