96 eclipse crank no start
- Thatboiiharris
6 years 2 months ago #42029
by Thatboiiharris
96 eclipse crank no start was created by Thatboiiharris
I have a eclipse came in the shop it cranks but won’t start so far it’s got no spark or injector pulse it seems like it’s not getting crank signal Rpms don’t move when you crank it , thing is I can’t get it to communicate with my scanner it powers up my wireless scan module but won’t link , it came from another shop that launched a parts cannon on it they put a new pcm , crank sensor and cam sensor both pcm’s light the engine light on dash any suggestions
- juergen.scholl
- Active partschanger
- Thank you received: 462
6 years 2 months ago #42031
by juergen.scholl
Replied by juergen.scholl on topic 96 eclipse crank no start
Get a wiring diagram and check powers and ground to the ecm. If present check the com lines. Make sure the ecm puts reference voltage out.
If you have an osciloscope you may want to look for cam/crank signals at the ecm, otherwise you can grab a voltmeter and a LED testlight.
- Thatboiiharris
6 years 2 months ago #42044
by Thatboiiharris
Replied by Thatboiiharris on topic 96 eclipse crank no start
Crank sensor has 5v signal wire ,8v and a ground verified good ground checked that same 5v At the ecm and have nothing but I do have my 5v ref checked on map and tps no codes finally got it to communicate in global obd
- juergen.scholl
6 years 2 months ago - 6 years 2 months ago #42045
by juergen.scholl
I understand that you got 5 volt on the signal wire at the ckp but not at the ecm on the same signal wire. This suggests it's a pull up design and the signal wire is open between the sensor and the ecm...
To make sure it really is a pull up circuit you may want to disconnect the sensor and now, on the harness side, you shouldn't have the 5 volt on the signal wire anymore. If the voltage is still present on the signal wire then it would be a pull down design, the ecm providing the 5 volt on the signal wire and maybe you weren't on the correct wire when testing at the ecm.
Do you get a signal from the crank sensor (at the crank sensor) while cranking or a rpm reading on the scanner?
Last edit: 6 years 2 months ago by juergen.scholl.
- juergen.scholl
6 years 2 months ago - 6 years 2 months ago #42046
by juergen.scholl
double post
- Thatboiiharris
6 years 2 months ago #42052
by Thatboiiharris
No rpm on the dash or on the scanner
- juergen.scholl
6 years 2 months ago #42053
by juergen.scholl
Do you get a signal at the crank sensor while cranking? If so check the wiring to the ecm. If not verify power, ground to the sensor once more, during cranking. If they proof o.k. it's down to the sensor/reluctor.
Time to create page: 0.549 seconds
