Mistubishi Canter duonic transmission
  • CYRUS nk
  • CYRUS nk's Avatar Topic Author
6 years 3 months ago #41795 by CYRUS nk
Mistubishi Canter duonic transmission was created by CYRUS nk
Hey?am trying to fix mistubishi Canter duonic transmission shifting issues and all is invain.i nid some help here guys.check wiring and seemed to be 100% ok kindly what does this code mean?does this truck nid a computer update?
6 years 3 months ago #41806 by Matt T
Replied by Matt T on topic Mistubishi Canter duonic transmission
Found this just searching to find out what this thing is.
gearsmagazine.com/magazine/introducing-the-mitsubishi-dsg/
Looking at the shift pattern in figure 8 the 4th/1st/6th Shift rail moving to the rear is the what REV/1st/6th have in common but isn't required for any other gears.
Gears also did a follow up article which mentions that the shift rails are monitored by position sensors. Take a look to see if your scan tool can display shift rail PIDs. Might even have bi-directional controls for them if you're lucky.
gearsmagazine.com/magazine/heavy-duty-sh...-duonic-6-speed-dct/
The following user(s) said Thank You: CYRUS nk
