FIXED 94 ford ranger 4.0 accleration issue FIXED
  • bandrauto
  • bandrauto's Avatar Topic Author
6 years 3 months ago - 6 years 2 months ago #41737 by bandrauto
ive got a 94 ranger with 4.0 v6. obdi. when you try to acclerate, its as if it cuts out, then comes back, cuts out then comes back. if you kind of ease into it, it wont do it. watching the limited data on the scanner, when it happens, both o2 drop to double digits. im having a hard time wrapping my head around it. i noticed the ground was loose and corroded on the battery, so replaced the cable end and exposed new wire, everything is good and tight there. positive is good. now, if i unplug the maf, it wont do it and it runs correctly down the road. when i test the maf, its got ground, power, both of which do not cut out when the problem occurs. it appears that im getting a good signal coming from the maf. looking at the scanner data though, its low. im thinking maybe the incorrect signal is getting to computer. my question i guess is this, in unplugging the maf, does the compute simply quit looking at the data it provides and just runs off the o2s?
thanks in advance
Last edit: 6 years 2 months ago by bandrauto.
6 years 3 months ago #41740 by Hardtopdr2
Replied by Hardtopdr2 on topic 94 ford ranger 4.0 accleration issue
You will need to test maf waveform signal for drop outs and glitches. What hz readings are you getting at idle and through the acceleration?
What are the g/s readings? Post a photo of pid data of maf, map, tps and o2 sensors. What is your fuel pressure looking like at idle and acceleration?
You will need to test tps, iac, fuel pressure, map and maf for these symptoms.
Were there any codes?
Let us know
6 years 3 months ago #41742 by Noah
Replied by Noah on topic 94 ford ranger 4.0 accleration issue
What are you using to read data on that? I was under the impression that there was no Ford live data until OBD2
6 years 3 months ago #41747 by Hardtopdr2
Opps got to typing and didn't look back. That is possible though looking at o2 with scope would give some "live data so to speak" along with probing tps or maf signal at same time. To determine when the glitch happens during the acceleration.
Where there is a will there is a way lol
6 years 3 months ago #41758 by Matt T
Replied by Matt T on topic 94 ford ranger 4.0 accleration issue
Noah wrote: I was under the impression that there was no Ford live data until OBD2
Pine Hollow did a vid on a '94 Ford a couple weeks back. Available PIDs look about the same as early OBD-II.
6 years 3 months ago #41768 by Noah
I'm blown away! I owned a 94 explorer for years and even with the adapter I couldn't get anything out of it except for koeo output test and trouble codes.
  • bandrauto
6 years 3 months ago #41828 by bandrauto
Replied by bandrauto on topic 94 ford ranger 4.0 accleration issue
there is a bit of data that i am able to read. i went ahead and tried a new maf on this one, but to no avail. when reading the data through the scanner, maf voltage reads .04 at idle and will go up when the throttle is manually turned, but never above one volt. with a meter hooked to the signal wire at the pcm connector, i can see the voltage is going up properly like it should.
does anyone know what the signal return wire should read? im assuming it supplies the voltage for the sensor but i cant find the information anywhere.
im leaning towards the pcm reading the voltage improperly, but i can't put my finger on why.
6 years 3 months ago #41833 by Hardtopdr2
Maf voltage should be able to go up to 5-12 volts square wave depending on ref voltage.
What are the measurements of each wire key on engine off (connected and disconnected) and key on engine running?
  • bandrauto
6 years 2 months ago #42374 by bandrauto
Replied by bandrauto on topic FIXED 94 ford ranger 4.0 accleration issue FIXED
Finally got this one. after exhausting myself too much, i pulled the computer and then removed the cover since it was a simple two or three screws to do so. there was a definite spot of damage at one of the tiny capacitors and the board looked corroded some. i decided to try my hand at trying to replace the capacitor. that made it worse, it just made the reading open. so, that lead me to believe that that was indeed my problem. finally ordered a computer for it, and after a number of weeks i just got it back. replaced it and fired it up, and the maf reading in the data stream was what it should be, instead of .04 and barely rising, it was .9 and went up as the rpm's increased. next time, i wont doubt myself as much.
6 years 2 months ago #42428 by Noah
bandrauto wrote: Finally got this one. next time, i wont doubt myself as much.
Good job B)
