Replace Lines on Rack?
- Tutti57
- Thank you received: 254
Nissan Technician
If I were you, I'd probably try to find a new O-ring, and use some RTV on the nut threads. Clean/dry the fittings in the rack and give it a few hours to cure.
- dfends@hotmail.com
- Thank you received: 12
- Tutti57
Well I'll let her know she is out of luck there. Thanks for the replies!
Nissan Technician
- Matt T
- Thank you received: 276
The Chrysler sticker see if they have a rack pick see if lines can be bought . If you can see if vin is there I can see if lines are available
- Hardtopdr2
- Thank you received: 150
If you have a hydraulic brake line flaring tool that does the quick connect fittings it will make those. If not the kit is not cheap ~$300 + for the kit but it does fuel lines, brake line 45 degree and iso metric bubble flare, single flare and a few others. It will flare stainless steel line as well and no mess ups like what is common with the little hand job deal.
- Tutti57
Nissan Technician
- Tutti57
Nissan Technician
- Tutti57
Nissan Technician
- Hardtopdr2
- Tutti57
bangshift.com/forum/forum/bangshift/tech...will-this-do-a-flare
I saw used racks were about $150 and I just don't have time to make it out to the pick and pull any time soon.
This with a rubber hose? Not sure if it's the right size though.
The pressure and return lines have the same ends on them, so if they are the same size I could get one or two of those and cut the end off and run a hose, maybe.
- Tutti57
I'll have my parts dept get me a pressure line tomorrow so I can compare it to what I have. if the sizes are the same, I'll cut the end off and make it work.
Nissan Technician
Tutti57 wrote: I'll cut the end off and make it work.
Nissan Technician
