Fuel Trim Discussion and hopefully some guidance....
  • Smeter12
  • Smeter12's Avatar Topic Author
6 years 3 months ago #41802 by Smeter12
Tyler,
Before I get down and dirty by checking compression of each cylinder and/or a leak down test, would the attached pics of Ford's IDS "Relative compression test" and "Power Balance Test at 1126 rpm and 1926 rpm" be of any assistance?
6 years 3 months ago - 6 years 3 months ago #41805 by Tyler
Smeter12 wrote: Before I get down and dirty by checking compression of each cylinder and/or a leak down test, would the attached pics of Ford's IDS "Relative compression test" and "Power Balance Test at 1126 rpm and 1926 rpm" be of any assistance?
That's what I'm talking about. B) I knew the IDS would do the Power Balance test, but I didn't know for certain if it'd do the relative compression test with this model year.
FWIW, I trust the IDS RC test when it suggests a low cylinder. Here's a link to where I was experimenting with the same test:
www.scannerdanner.com/forum/diagnostic-t...flow-test.html#10022
Last edit: 6 years 3 months ago by Tyler.
  • Smeter12
6 years 3 months ago #41807 by Smeter12
Wow, I feel like royalty with all the help that you guys have given me on this post. A HUGE thanks to all......very helpful !!!!!!!!
6 years 3 months ago #41810 by Matt T
Smeter12 wrote: Matt T wrote: "That injector definitely ain't firing every 180*".[/size]
Not sure I understand. It is not unreasonable for a manufacturer to spray all injectors every half turn of the camshaft (i.e. one full turn of the crankshaft) when trying to get the vehicle started.... respectively.... am I missing something?
You're missing how a 4 stroke engine works. The intake, compression, power and exhaust strokes are all half a crankshaft revolution/180* so the engine takes two crankshaft revolutions/720* to go from compression stroke to compression stroke on one cylinder.
So it's obvious that injector wasn't firing every 180* because there were too many noticeable compression humps between firings. A 6 cylinder will have one or two compression strokes per 180* not three.
6 years 3 months ago - 6 years 3 months ago #41812 by guafa
Hi everyone,
I am lost with this one. We are looking for fuel trims and misfires, but that compression waveform seems an engine which not even start. Is this engine running?
Why are we watching secondary spikes at every cylinder? Shouldn't be watching 1&5 cylinder spikes?
Last edit: 6 years 3 months ago by guafa.
6 years 3 months ago #41815 by Hardtopdr2
Thats kinda what i was thinking. Really makes me think that coil pak is bad. One thought would be to disconnect #5 injector and disconnect #5 sparkplug wire and clip it to ground. Sometimes i wonder what ford was thinking.
6 years 3 months ago #41821 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Fuel Trim Discussion and hopefully some guidance....
Cutting to the chase -- (1) The engine has a fair ammount of miles undere its belt. (2) Low speed misfires on particular cynders that smooth out at higher RPM.
Those two factors alone point straight to a compression issue, even more so as it passes the water test for vacuum leaks.compression
The cranking compression test result is fairly clear very poor compression on three cylinders, personally I wouldn't even bother with a leak down or old style compression test as it looks to me like a major valve issue rather than a piston ring issue either sticking valves or a really badly burned valve as shown in Tylers screen cap.
6 years 2 months ago #41877 by Fallontech
On a waste spark system, if you short one of the spark plug wires, you've basically shorted them both. The wasted spark also needs a gap to allow the firing plug to achieve ionization voltage too. Clipping it to a spark tester or an old grounded spark plug would be a better idea.
6 years 2 months ago #41879 by Fallontech
I see compression problems on cylinders 4 5 3 and 6. Number 6 should have been as high as number 2 after spinning freely past number 3.
6 years 2 months ago #41881 by Fallontech
I too suspect a bad coil for 1,5. During a misfire, the oxygen is not consumed in a burn and exits past the O2 sensor, tricking it into seeing a lean condition and adding more fuel with the ST fuel trim. Fix the miss and see where the fuel trims go.
  • Smeter12
6 years 2 months ago #42218 by Smeter12
Hey,
For what it is worth, sorry for the delay in getting the concluding results to this post. With that said, I got down and dirty by doing a compression test on this 2002 Ford Ranger 3.0L V6 as per Tyler's recommendation.
Background info on the compression test:
- started the engine up and let it idle until warm; turn off
- removed all 6 spark plugs
- used my Lang Tools TU-30A Compression Tester Set (i.e. I believe this gauge set is expensive enough to give reliable compression readings) to take compression readings
- pulled fuel pump relay out of relay box (as wife was my assistant for cranking the engine from the cabin of the vehicle)
- disconnected 4 pin wiring harness to ignition coils (knowing my luck, residual fuel would be hanging around and I would have had a 6 nozzle flame thrower)
- attached my battery jumper box to ensure battery would have full power while testing all 6 cylinders
- wife cranked the engine with the gas pedal to the floor
Here are the results from the gauge compression test:
- Cylinder #1 - 25 psi
- Cylinder #2 - 135 psi
- Cylinder #3 - 170 psi
- Cylinder #4 - 115 psi
- Cylinder #5 - 25 psi
- Cylinder #6 - 5 psi
Additional testing:
- checked the crankcase - blocked off the intake (i.e. breather) to the crankcase as well as exhaust (i.e. where PCV valve sits) and shoved a vacuum gauge into the oil dipstick. After a little bit of time, I had a reading of -7 psi.
- water test - did the good old "scannerdanner" test looking for intake leaks, but I couldn't find any. Not sure about the lower plenum though as it is somewhat difficult to get water down there at the front (i.e. 12 o'clock) and rear (i.e. 6 o'clock) of the lower intake plenum.
For sh*ts and giggles, I've attached the compression test results from the Ford IDS software to this post (i.e. Pic 7). Pretty cool how the IDS software dialed in the strength/compression of each cylinder and how it corresponds to the gauge compression test results.
CORRECT CONCLUSION BASED ON THE NUMBERS?
I really don't think the pistons (piston and/or its compression rings) are bad seeing that the crankcase could build good vacuum with the breather and PCV valve area blocked off. Instead, I think I have some type of valve train issue in both the left and right cylinder head. Using the fuel trim numbers (noted at the beginning of this post thread and in Pic 26 attached to this post) and the gauge test compression results, I am guessing cylinder 1, 5, and 6 have some type of valve train issue where by the valves (intake & exhaust or both) are not seating properly and are allowing large amounts of intake air (i.e oxygen) into the cylinder [hence the high positive LTFT numbers** at idle (pic 26)] on the intake stroke. Good conclusion?
** when looking at the LTFT numbers, focus on the line graph and how it stays high around 30 and not the 15.62% and 14.84% which simply represent a moment in time measurement as the snapshot was taken
6 years 2 months ago #42220 by Matt T
You haven't reached a "conclusion" yet if you're considering repairing that engine. Next step is leakdown testing to find out where those cylinders are leaking.
6 years 2 months ago #42255 by Noah
If it were actually firing every 180° it would be evident in this waveform.
This is showing one injection event every 720°
Time to create page: 0.360 seconds
