1999 dodge ram
9 years 8 months ago #5526 by laird
1999 dodge ram was created by laird
3500 van,stalling
Van stalls when driving, then no start.No bus appears on odometer. replaced pickup coil in distributor &
engine computer. Sometimes it will run for days. I found that when it stalls I open the hood & push on the
connector on the drivers side going into computer. Thought it was a loose connection so I tightened it up
with zip ties. It stalled again the other day.
Please help.
Laird
9 years 8 months ago #5531 by ImBack218
Replied by ImBack218 on topic 1999 dodge ram
Do you think the engine computer could be losing power or ground? What happens when you wiggle on the connector when the engine is running? How long before you are able to start the engine again? What are you missing when the car is not starting(spark, injection pulse, 5v reference)
9 years 8 months ago #5588 by laird
Replied by laird on topic 1999 dodge ram
Sorry it took so long. I just got the wiring diagrams today,haven't had a chance to check anything yet.
When I wiggle connector with engine running it doesn't affect it. It stalled again today opened hood
when I wiggled connector I heard a click in the power distribution center sounded like a relay, I got back
in & it started right up. It ran for the rest of the day.
Thank you for your input.
9 years 8 months ago #5594 by Tyler
Replied by Tyler on topic 1999 dodge ram
Hey laird! The clicking relay when you wiggle the computer connectors kinda suggests an ASD relay problem to me. The ASD relay controls power for the injectors, coil, and fuel pump, which definitely explains the stall. You could verify this by checking for power at any of the injectors (which are kinda hard to get to, I know) or the ignition coil during the crank no start.
The next time you get it to stall, see if you can wiggle individual wires at that connector. Let us know which one gets a response, and we can look it up on a wiring diagram, and see where it takes us. :cheer:
9 years 8 months ago - 9 years 8 months ago #5600 by ImBack218
The relay clicking in the power distribution box could be the ASD relay or the Fuel Pump relay, both of which are ground-side switched by the engine computer. It give us some direction. It would be helpful to know what you are missing when the car does not start. You want to do all of your testing only when the car doesn't start.
Is there power getting to the injectors when cranking?
Is there power getting to the ignition coil pack when cranking?
Is there power getting to the fuel pump when you are cranking?
Do you have an intact 5v reference circuit? This video will help you if you're unsure
Last edit: 9 years 8 months ago by ImBack218.
9 years 8 months ago #5613 by laird
When the van doesn't start there is no power to the gauges,fuel pump or anywhere.
All I have is a multimeter to test things.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
9 years 8 months ago #5662 by cheryl hartkorn
Replied by cheryl hartkorn on topic 1999 dodge ram
the no bus to me sounds like your losing a power feed to the computer, when it happens next time check for a 5 volt ref at the tps. you may have a sensor that is intermittently shorting and pulling the reference voltage down. when no bus appears im pretty sure its going to be a no communication with a scanner
9 years 8 months ago #5715 by laird
I tested the tps with the key on , (not running) by back probing I had 5 v ref in. .66v out. on wot I had
3.67 out. It's difficult to test when stalled as I would have to take the dog house out on the side of the road
or at a red light........next?????
P.S. Didn't find any problems with any grounds.
9 years 8 months ago #5755 by Tyler
Does your 3500 have a 5.2 or a 5.9L? Just want to know for diagram purposes.
Yeah, the dog house will be too much work to take off at a moments notice... How about this? I did some digging, and I found the fuse that the ASD relay feeds to power the ignition coil, injectors, O2's and PCM. It's listed as fuse 19/20 in the Power Distribution Center. Here's a partial wiring diagram:
The next time the van acts up, jump out and check for power at this fuse during cranking. If there's no power, then we're going in the right direction with the ASD relay. If there IS power, then we need to go in a different direction.
The following user(s) said Thank You: laird
9 years 8 months ago #5768 by laird
It is a 5.9. I will try what you suggested next time it stalls.
9 years 8 months ago #5897 by laird
I replaced the tps. No such luck, it stalled 3 times today. Took it to mechanic, he said nothing he could do
unless it stalled while I was there.......Next??????
9 years 8 months ago #5898 by Tyler
laird wrote: I replaced the tps. No such luck, it stalled 3 times today. Took it to mechanic, he said nothing he could do
Any luck checking that fuse when the engine stalled?
I still think you were on the right track with that connector under the hood, near the computer. If you can find a way to consistently manipulate that connector to produce a stall, then we need to dig into that connector.
9 years 8 months ago #5940 by Doc n2mx
Replied by Doc n2mx on topic 1999 dodge ram
Its seems to me that you might have a bad connection, when it runs wiggle the wires, carefully. Strip back the loom as far back as you can and wiggle tug each wire if you can I think you will find one bad or more. Also you might unplug and check the connectors for (the green crud) both ends. Re seat the plug (don’t force or bend the pins)
9 years 7 months ago #6057 by laird
I decided to go for it. I remove all of the wires from the connector, I saw some of the wires were frayed & some connections loose on the pins. I squeezed all connections and reinstalled wires on pins. Then I sprayed entire
connection with liquid rubber. Not very professional, but it worked. I will try & find a new wiring harness & connector.
Meanwhile it"s purring like a kitten.
Thank you all for your help.
Laird.
Time to create page: 0.326 seconds
