2009 Nissan Frontier Intermittent A/C on 2 and 3 speed fan setting
  • forumjoe
  • forumjoe's Avatar Topic Author
6 years 3 months ago - 6 years 3 months ago #41372 by forumjoe
Thanks Hardtopdr2,
attached are two pics of the wiring diagram as requested. I see where you are going and I think I can test that by disconnecting the blower motor connector and reading the white/green terminal on a DVOM for voltage. I am having trouble locating the blower motor relay in the engine room, maybe it is located in the passenger room. Anyway thanks for keeping on with the diagnosis and I will try to do what you suggest, it is an intermittent issue though so I will have to wait til it won't work again to test, that shouldn't be long though. But the blower motor blows in all speed settings it is the A/C that stops working in speeds 2 and 3, the A/C button light does not come on or it flickers and will either go out and the compressor stops working or it will stay on and I have A/C working.
Thanks Again Htop
Joe
Last edit: 6 years 3 months ago by forumjoe. Reason: additional commentary
  • forumjoe
6 years 3 months ago - 6 years 3 months ago #41401 by forumjoe
Hardtopdr2,
As I thought my ThinkDiag scan tool would not let me access the BCM I played around some more with it today and found that I could in fact access the BCM. Turns out when the A/C is out on #2 and#3 settings the BCM is seeing a fan switch off and an A/C switch off message however when the A/C switch flickers the A/C switch shows on momentarily and the fan blower switch shows off, when the A/C IS working on either #2 or #3 setting both the signals to the BCM show on ( A/C and fan blower switch). But the fan never goes off no matter what the BCM sees. What do you think?
Looking at the schematics it seems it could be the brown wire connection to the red wire in the Front Air Control wiring or the red wire in the BCM, somewhere there is a no fan signal being sent to the BCM even though the fan motor is actually blowing, it wouldn't be anything relating to the resistor pack would it?
Joe
6 years 3 months ago #41403 by Hardtopdr2
With what your seeing this still would indicate problems with intermitant failure of blower motor, intermitant failure of blower motor resistor, bad switch, bad power feed, bad ground and possible bad relay. Though with the signal to bcm as far as it is on getting signal that is good. Now you just need to find out if power is getting cut to a/c switch and fan switch. Backprobe the power feeds to the smaller harness connector (the one in the middle of the fan and a/c switch panel). See if the power cuts out the same time the a/c cuts out.
  • forumjoe
6 years 3 months ago #41405 by forumjoe
Okay but I know power must be getting to the fan switch because the blower never quits it stays running on all speeds, the BCM thinks that the blower fan is off, but it is not, and I think the AC turns back off if it thinks that the blower fan is off,as the BCM says it is.
joe
6 years 3 months ago #41406 by Hardtopdr2
Opps sorry miss understood you then if that is the case of the fan stays running at that selected speed then the switch panel is bad only if your system pressures are good (meaning if your not low on refrigerant and the pressure sensors are working like the should. You should be able to see your system pressures with the scan tool under the bcm module.
Having said that i believe your control panel has the issue but the only other thing that can shut a/c off like that is a pressure switch on the high side line or low side line. Which you should be able to confirm with scan tool or a set of r134 refrigerant gauges. The data pids will say psi reading if your scanner has that ability
  • forumjoe
6 years 3 months ago #41413 by forumjoe
Hardtopdr2,
I really appreciate your diligence on helping me diagnose this problem before I start throwing parts at it. That said, I am thinking if this is an intermittent problem and sometimes the, A/C works on those 2 settings wouldn't that eliminate the pressures in the system? Because it works when it wants to I am thinking front control module, relay(s), wire connection or maybe corrosion somewhere. Do you agree? I will check the pressures at the BCM if I can. What is bothering me is that the fan on signal to the BCM is coming from the red wire that is connected to the brown wire from the resistor pack in the schematics if you notice that. When the A/C doesn't work the BCM has a fan off indication, but the fan is blowing.
I am fortunate that it always works on the highest setting so I am not without A/C altogether and I can take the time to figure out what the problem is, I hope you don't get tired of my questions and I am glad you are still with me.
joe
6 years 3 months ago #41414 by Matt T
forumjoe wrote: Okay but I know power must be getting to the fan switch because the blower never quits it stays running on all speeds, the BCM thinks that the blower fan is off, but it is not, and I think the AC turns back off if it thinks that the blower fan is off,as the BCM says it is.
joe
It appears that the FAC is turning off AC because it thinks the blower is off. The BCM blower input is grounded, for fan on, either by the fans #1 speed wire or by the FAC. The OEM SI shows both "options" but it really doesn't matter which is correct at this point. Though it's bugging me so I'd have to poke around with the DMM to confirm how it really works.
The FAC is probably also looking for 0V on the fan speed #1 leg to detect that the blower is on. You need to get on the back of the FAC and take voltage readings on that wire at the blower switch. You'll probably see some voltage, to ground, on that wire in the 2 and 3 speed positions which is making the FAC think the blower is off. Most likely caused by bad blower switch contacts though there are other less likely possibilities so take some measurements and report back.
And since you seem reluctant to go after the FAC maybe this video will help.
6 years 3 months ago #41416 by Tyler
I'm still with you. :silly: Great job getting the BCM data. Definitely makes me feel better that this FR BLOWER circuit is related.
Mostly trying to decide how this circuit is supposed to work... I feel like the key is in here?
It would seem to me that the BCM is providing a 5V signal on the FR BLOWER circuit, and is looking for the FAC (or the blower resistor/switch?) to pull it down to signal that the fan is on. But this whole chart makes no mention of the resistor or the switch. :angry:
6 years 3 months ago #41417 by Matt T
Tyler wrote: It would seem to me that the BCM is providing a 5V signal on the FR BLOWER circuit, and is looking for the FAC (or the blower resistor/switch?) to pull it down to signal that the fan is on. But this whole chart makes no mention of the resistor or the switch. :angry:
Yeah the SI sure is contradictory on this one. If the #1 speed leg and BCM blower input really are wired together it'll read battery voltage with the blower off not 0V or 5V.
  • forumjoe
6 years 3 months ago - 6 years 3 months ago #41419 by forumjoe
Matt, Tyler and Hardtopdr2, You guys are amazing, glad you all are still following this post. Matt thanks for the video and test info, Tyler thanks for the SI voltage test step chart, and Hardtopdr2 thanks for throwing suggestions for me to try. I am going to keep at it but I think I will drive around with my ThinkDiag plugged in and see if things change at the BCM when the A/C works and when it doesn't. To be continued. You guys are the best.
joe
I am thinking if I use my Power Probe to send a ground to the #1 switch contact while I am watching the BCM signals with my Think Diag hooked up after I access the FAC switch contacts that would lead to an almost solution if the BCM shows Fan On signal after I ground the switch contact for #1 setting as that is seemingly the route it uses to the BCM for fan and A/C signals. Then if I remove the ground from the #1 switch contact and the signal @ BCM says fan off it probably is the switch contact. Or it could be the Brn or Red signal wire.
Do you guys agree?
6 years 3 months ago #41590 by Tutti57
I'm not sure if this is helpful. I started reading through the posts but was exhausted. Let me know if there is any factory info you are looking for.
Nissan Technician
  • forumjoe
6 years 3 months ago - 6 years 3 months ago #41592 by forumjoe
Tutti57,
thanks for the diagram, it is a little hard to make out on screen, but I am not sure that is where i need to check. The blower fan works but my BCM says it is OFF, when the problem shows up. Again it is intermittent because i can get it to operate correctly sometimes. I am thinking it is a ground problem or an intermittent open or corrosion in the wiring from the fan switch to the BCM. I am hesitant opening up the Fan Control Switch for testing, I don't want to make it worse while it is so hot out, as it always works on #4 fan setting. I do get a little A/C switch light flickering (from time to time on the #4 setting) but it always works.
As for factory info I could use a ground location chart for the blower fan control switch and that system if that is possible.
Thanks and stay tuned,
Joe
6 years 3 months ago #41629 by Tutti57
Wow, that picture didn't come out good at all. It basically just shows the communication between everything in the system, including the compressor clutch, with a brief explanation.
I'm working tomorrow so I'll try to remember to look up that ground location. I think I briefly saw mention of there being two different types of manual AC setups on these trucks too for some reason.
Those four cylinder 2wd are super rare here. I think I've only seen two ever come in.
Nissan Technician
  • forumjoe
6 years 3 months ago - 6 years 3 months ago #41690 by forumjoe
Tutti57,
OK thanks for going through the trouble, I am seeing the #4 A/C button Light setting also flickering more than it has been in the past, it didn't use to flicker at all, but today it seems to be an issue now too. Now when I have my ThinkDiag scantool hooked in it shows the fan signal as being off whenever the light flickers as well as the A/C switch which I assume automatically turns itself off if it doesn't get the Fan ON signal. The schematics show power going directly to the Blower motor and not through the resistor pack for Fan setting #4, SO THE FLICKERING MIGHT BE A BAD GROUND OR CORROSION at the Fan Control Switch or relay but the fan still blows on Speed #2,3 &4 on speed #1 the fan seems to be on or off intermittently, like sometimes I feel air flow on#1 and sometimes I don't, could that still be in the resistor pack? Or could it be the signal wiring at fault. There is something for you to think about.
What do you think?
joe
6 years 3 months ago #41748 by Hardtopdr2
With the speed one setting intermitantly blowing/not blowing yes that could be the blower motor resistor. To test for that when it happens ohm the two wires that go in and out of the blower motor resistor for speed 1 with key off engine off. Best way to do it is to make a set of wires with sewing needles or tpins soldered to one end and shrink tubing / electrical tape wrapped covering the soldered ends of pins. Then with the other end a insulated female spade connector crimped on and sticking this end out of dash. Then when problem happens grab multimeter from glove box /center console and connect multimeter to it. Then turn car off key in off position and turn multimeter to ohms and take a reading. Speed 1 setting should be three times the ohms as speed three. So if you want to probe all the speed settings and mark each female end of the wire probes to what speed they are for that would make it possible to quickly test blower motor resistor when the glitch happens fairly quick.
  • forumjoe
6 years 3 months ago - 6 years 3 months ago #41756 by forumjoe
Hardtopdr2,
Thanks, I am not sure where to connect the wire for #1 setting. I think you are telling me to backprobe the #1 resistor pack wire to ground and read the ohms on the multimeter with the key in the off position, but based on the schematics I only see one wire going IN to the resistor for #1 fan switch setting. Am I missing something? You mention 2 wires for the #1 setting at the resistor. What don't I see?
Do you mean to back probe the red wire going in to the resistor and the blue wire going out to the fan motor, with T pins and take voltage readings there? As well as the other resistor wires and the blue wire to take voltage reads for all three resistor settings with the fan in each speed setting with the key in ON , engine either off or on.
6 years 3 months ago #41759 by Hardtopdr2
You will need to tap into the blue wire and red wire at blower motor resistor to ohm test the fan speed one setting of blower motor resister. If you wish you can ohm test all 3 wires to the red wire at the blower motor resistor when it glitches to see which resistor is going bad.
Ohm testing speed one will ohm all three resistors in resistor pack.
Ohm testing Speed 2 will ohm test two resistors in resistor pack
Ohm testing speed 3 will ohm test one resistor in resistor pack.
If one of the resistors is failing the ohm reading will say OL for out of limit meaning its open or it will read way higher than 3 times the reading of one resistor.
6 years 3 months ago #41760 by Hardtopdr2
When ohm testing a circuit you need to have the key off (key out of ignition) with engine off. If not you will fry your multimeter when testing ohms aka "resistance."
When testing DC voltage (multimeter set to dc volts (straight line with 3 dashes underneath) you can have key on engine on. Which you can measure voltage from blower motor through the through each setting of switch when it glitches to test speed switch.
With the a/c button you can probe the powered side first to see if button is loosing power when glitches are happening. If it is loosing power then trace that wire to its source and with the car off key out of ignition ohm test that wire from the button end to where it goes and see what ohms its reading. It should read 0 ohms. The same goes for the ground wire coming from a/c control panel to ground. Let us know what you find out.
  • forumjoe
6 years 3 months ago #41780 by forumjoe
I will eventually poke some wires etc. I am just leary of frying something in my system if I poke wrong. I will let you know the results.
joe
  • forumjoe
6 years 2 months ago - 6 years 2 months ago #42140 by forumjoe
New twist Guys, I am now having intermittent A/C on fan speed #4 too. That does not go through the resistor pack according to the schematics. This just started happening over the weekend. I thought it might be a bad blower motor and it still may be but I pulled the blower fan relay out today and I think I bench tested it properly but got no continuity in either set of pins on the 6 pin relay after I energized the coil directly from the battery posts. I am attaching a jpeg of the relay and wondering if I am testing it correctly. when the coil is energized pins 5&3 should have continuity as well as pins 6&7. Is that correct? I could not attach the jpeg for some reason but it is a 6pin Jideco Nissan 25230 7996A 12v. Any thoughts?
Last edit: 6 years 2 months ago by forumjoe.
Time to create page: 0.473 seconds
