2004 sub legacy 2.5L no crank
6 years 3 months ago #41121 by clifz
2004 sub legacy 2.5L no crank was created by clifz
ladies and gents...….this 04 Subaru has a electrical problem.....sometimes after running the car (engine warm) I will turn the
key and nothing (no noise) it invariably will restart after 1-10 minutes , its never not restarted. Lately it sometimes does this when its
cold, but again it eventually starts . have replaced battery..starter...batt cables .. ignition switch. I am in the dark on this one,can anyone
can anyone shed some light on this ?
6 years 3 months ago #41125 by Cheryl
Replied by Cheryl on topic 2004 sub legacy 2.5L no crank
You have to see if your getting power on the signal wire and big battery wire at the starter when it malfunctions. Also use meter and go from battery negative to block ground to check the block ground. Should be below 200mv when cranking
The following user(s) said Thank You: clifz
