2003 Ford Expedition 5.4 p0171
- Thatboiiharris
6 years 3 months ago #41022
by Thatboiiharris
2003 Ford Expedition 5.4 p0171 was created by Thatboiiharris
Smoke tested already I couldn’t find any leaks other than the idle air control valve which has been replaced new iac still seems to have smoke coming from it I’m guessing it’s normal and swapped both 02 sensors from bank to bank still no change
- Thatboiiharris
6 years 3 months ago #41023
by Thatboiiharris
Replied by Thatboiiharris on topic 2003 Ford Expedition 5.4 p0171
Also put a vacuum guage to it got 20inhg and pinched off brake booster
And used a known good maf still no change in fuel trims
- Cheryl
- Thank you received: 215
6 years 3 months ago #41033
by Cheryl
Replied by Cheryl on topic 2003 Ford Expedition 5.4 p0171
Possibly a restricted cat because one bank is lean and one is rich. Have you checked fuel injector flow rates bank to bank
- Thatboiiharris
6 years 3 months ago #41036
by Thatboiiharris
I did an injector balance test all of them drop 13 to 15 psi each
- Cheryl
6 years 3 months ago #41038
by Cheryl
Did you check for an exhaust restriction?? With one bank rich and one lean I’d suspect it
- Thatboiiharris
6 years 3 months ago #41123
by Thatboiiharris
I did a vacuum test since I don’t have a back pressure tester it had 21inhg of vacuum at 2500 rpm
- Cheryl
6 years 3 months ago #41126
by Cheryl
Any TSBs? How’s it drive low on power??
