[FIXED]95 Buick Lesabre No Crank No Start
- popoften
- Thank you received: 22
No crank no start, all I get is a click of the solenoid. DVOM shows 12.4 volts across battery terminals with engine off, and I had battery (bought new 8 months ago) load-tested at Advance Auto, it checks out fine. Connections are clean. I measured only 60 mV of voltage drop from battery+ along positive battery cable to main post on starter motor with key in crank position. Only 20mV of voltage drop from starter case to battery negative again with key in crank. Post on starter where ignition wire connects is getting battery voltage with key in crank.. I did notice that with Key off, I see battery voltage at main positive starter post where positive battery cable connects. But at same post when key put in crank position, almost all the voltage drops; down to single-digit millivolts. I think we are looking at a bad starter/solenoid unit, but I admit I have no idea what to make of that last measurement, the one where almost all the voltage drops out when measured across the starter with key in crank.
Do you guys think I am correct in leaning toward calling a bad starter?
- SniperDan
- Thank you received: 28
The heavy cable on the starter should maintain battery voltage with the key in crank, if you have battery voltage there not cranking, and almost nothing in the crank position, you have a significant voltage drop on the heavy positive cable. This being a GM that likely uses side post terminals, I would inspect both the positive and negative cable ends at the battery for corrosion, which is notorious for causing this condition in these vehicles.
~W. Edwards Deming
- SniperDan
~W. Edwards Deming
- popoften
To be more clear, where I see all the voltage drop is with my positve DVOM lead connected to the main post where the positive battery cable connects to the starter, and with the negative lead clamped to the starter case.
- SniperDan
~W. Edwards Deming
- popoften
- SniperDan
~W. Edwards Deming
- popoften
- popoften
Thanks guys for all your help and guidance.
- Thank you received: 1138
popoften wrote: Well I feel like an idiot. Finally got back out there and redid my voltage drops. Turns out I was losing 10.5 volts between the surface of the battery side post and the pos starter cable cable end where it connects to the battery. Not due to corrosion; connection was just not good. Fixed, now car starts nicely every time.
Glad to hear it, sir!
I got to this thread late, but this part stuck out to me:
Seeing these numbers, my first thought was that there's no current flow. :blink: It sounds weird, but on high current circuits like this, some voltage drop across connections is normal and expected. A few hundred mV on starter in-rush, at least, usually more.
That's the tricky part about voltage drop testing. You did the test right, and it DID indicate clean connections... between the two points that your meter was connected. Not trying to lecture you, sir, just making sense of your initial readings.
