Low CAN voltage Mercedes e550 w211 -06
  • larsk84
  • larsk84's Avatar Topic Author
6 years 4 months ago #40689 by larsk84
Hi
I have a weird problem. To begin with I cannot establish link to OBD port. I measured continuity on pin 4,5 to ground = all OK. I have good voltage on pin 16. Between Can high and can low (pin 6, 14 ) it's 70 ohm.
Here's what strange:
* CAN-HIGH pin 6 to 5 = 0,67 V
* CAN-LOW pin 14 to 5 = 0.4 V
(both with engine on/shut off)
Why is my readings so low. Anyone have an idea what I should check next?
/Lars
6 years 4 months ago - 6 years 4 months ago #40690 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Low CAN voltage Mercedes e550 w211 -06
You are going to have chase down the high ressistance by disconnecting modules
Last edit: 6 years 4 months ago by Andy.MacFadyen.
  • larsk84
6 years 4 months ago #40693 by larsk84
Replied by larsk84 on topic Low CAN voltage Mercedes e550 w211 -06
Is my resistance ok? Worth mentioning I have ABS,ESP warning lights on dash. I quess I start disconnecting modules to brake-system First ( ABS unit, ESP Module)
6 years 4 months ago #40701 by Tyler
Replied by Tyler on topic Low CAN voltage Mercedes e550 w211 -06
70 ohms isn't perfect, but it's probably not enough to cause the kind of voltages you're seeing.
Do you have any continuity between 4/5 and 6 or 14? If no, that'd rule out a static short to ground.
From there, I'd keep disconnecting modules like Andy suggested.
  • larsk84
6 years 4 months ago #40741 by larsk84
I measured continuity between 4,5 and 6 = 197. Continuity between 4,5 and 14 was 86.
Is results in ohm ? Anyway what does this say?
6 years 4 months ago #40744 by Tyler
Those readings represent a resistive (not direct) short to ground. Your CAN voltages are low because they're getting pulled low by a short, either in a module or in the wiring.
Any evidence of water intrusion? Because a water-logged module would certainly account for those readings.
  • larsk84
6 years 4 months ago - 6 years 4 months ago #40756 by larsk84
I disconnected rear Sam main power Cable. Now I have 1,6 Volts (originally 0,6 v) On CAN_high and 0,6 volt CAN_low ( originally 0,4 volts)
I quess I must also disconnect can wires to this module.
Last edit: 6 years 4 months ago by larsk84.
6 years 4 months ago #40768 by Tyler
1.6V on CAN-H and .6 on CAN-L is definitely better, but still being pulled to ground. I think you're on the right track with the rear SAM.
You might also consider what the rear SAM powers, and if you removed power to other modules/components when you disconnected that main cable.
  • larsk84
6 years 3 months ago - 6 years 3 months ago #41155 by larsk84
Im not really getting smarter. I have attached a diagram(zip file) over the N93 (gateway module) which connects to X11/4 (DLC). Gateway talks to all modules.
I could lift the strip connector and measure (volt) each metal strip on the CAN distributor, And remove interconnect plug between the CAN distributors and at same time checking voltages on metal strips.
Last edit: 6 years 3 months ago by larsk84.
6 years 3 months ago #41200 by tech25
Replied by tech25 on topic Low CAN voltage Mercedes e550 w211 -06
Hello, please lets start fresh. with all modules connected in the vehicle. ( stock ) please disconnect the battery negative terminal.
Measure resistance across pin 6 and 14, should be around 60 ohms plus or minus 10%
then measure from pin 6 to ground, and 14 to ground, you should have more than 500 ohms.
reconnect negative battery terminal.
turn meter on dc volts and measure voltage at pin 6 and ground
and measure voltage at pin 14 and ground.
voltage will change depending upon if the network is asleep or awake. please refer to this picture and compare voltages
  • larsk84
6 years 3 months ago - 6 years 3 months ago #41230 by larsk84
DLC readings:
Battery disconnect:
Resistance across pin 6-14 = 60ohm
Resistance pin 6 to GND = 99 Ohm
Resistance pin 14 to GND = 41 Ohm
Voltage readings Pin 6 to GND :
in car closed Doors 5 min = 0,03V
When open Door = 0,68 V
Ignition on = 1,64 V
Voltage readings pin 14 to GND
In car closed Doors 5 min = 0,02 V
When open door = 0,35 V
Ignition on = 0,58 V
  • larsk84
6 years 3 months ago - 6 years 3 months ago #41239 by larsk84
theoretically, shouldn't I get the same low readings if I measure directly on the Gateway. If so the gateway must be faulty I quess. I checked yesterday and I had constant 12v going in on N93
  • larsk84
6 years 3 months ago #41259 by larsk84
I fixed the issue now. To my gatewat there is two connectors. One connector is to the GPS unit. I removed this connection and I got 2.5 V idle on each CAN-L and CAN-H. And with ignition on - there was 3.5 V and 1.5 V. I manage to connect my scanner now.
I have 2 fault codes in ESP (Electronic Stability Program) which handles the ABS, ESP.
441a and 7284
6 years 3 months ago #41269 by tech25
Glad you are able to track down the problem. good job.
Time to create page: 0.490 seconds
