2012 Nissan rogue
  • chief eaglebear
  • chief eaglebear's Avatar Topic Author
6 years 4 months ago #40403 by chief eaglebear
2012 Nissan rogue was created by chief eaglebear
Hi I have a 2012 Nissan rogue the brakes are locking up for some reason I could not find a tsb on it,I did see people on the forums having same problem to no avale there is a U1000 code on Ecm or Tcm I believe and there is a mass air flow code too. Another tech was thinking it's the brake booster.!?. My thinking is it is a No Comm with TCM and the brakes locking up is a protectory function !?.
6 years 4 months ago #40407 by Cheryl
Replied by Cheryl on topic 2012 Nissan rogue
Does the tcm communicate with your scanner?? Also check your brake lights I had one brake lights didn’t work had low power replaced switch took care of it
6 years 4 months ago #40409 by Matt T
Replied by Matt T on topic 2012 Nissan rogue
chief eaglebear wrote: I did see people on the forums having same problem to no avale
I did an quick search and there's so much parts cannon fire it's like being in a war zone:lol: And hits going back to models that probably didn't even have ABS. Did find this one which sounds like it'd be worth checking if the brakes are dragging before they actually lock.
www.nissanclub.com/threads/brakes-dragging-locking-up.514026/
Beyond that I'd be tempted to pull the ABS fuses and see whether that "fixes" it. Quick and dirty hack which should tell you whether it's a braking system or a control problem.
  • chief eaglebear
6 years 4 months ago #40482 by chief eaglebear
Replied by chief eaglebear on topic 2012 Nissan rogue
FIX: it was a brake booster I guess the mechanic fixed it I overthought this one sorry
