2003 dodge grand caravan oxygen sensor wiring
  • Bennytwostep
  • Bennytwostep's Avatar Topic Author
6 years 4 months ago #40345 by Bennytwostep
2003 dodge grand caravan oxygen sensor wiring was created by Bennytwostep
2003 Dodge Grand Caravan. I am making a new oxygen sensor wiring harness. I cannot adequately access the wiring to find the break in the main harness. That said, there are 2 questions I cannot answer. The br/wh wire splices and goes to the ASD relay and fuse. Is thus also pin 6 on PCM C1? Second, the bk/bl ground wire from the sensor wiring.. Does this go directly to ground, and if so, in rewiring, can I simply ground it to the block and keep moving? I know this would technically call for a new harness, but the van belongs to a vet, its not in great shape, but its his only transportation. I've had this thing for a while, and he has to have it back yesterday. I don't do many of these vans any more, and I've NEVER had a problem where I just cannot get to the wiring. Help appreciated!
6 years 4 months ago #40360 by Chad
Bennytwostep wrote: The br/wh wire splices and goes to the ASD relay and fuse. Is thus also pin 6 on PCM C1?
Yes. It, also, powers the Injectors and Coil Pack.
Yes.
  • Bennytwostep
6 years 4 months ago #40416 by Bennytwostep
Replied by Bennytwostep on topic 2003 dodge grand caravan oxygen sensor wiring
so I need to splice the new wire into br/wh but also maintain the current connection, or I'll lose coil and injectors. correct?
6 years 4 months ago - 6 years 4 months ago #40420 by Chad
The PCM, alternator, fuel injectors, coil pack, and both oxygen sensors, all get power from the ASD relay. If you are running a new wire to the O2 sensor (from the ASD relay), then you can cut the old one and cap/tape it off.
Last edit: 6 years 4 months ago by Chad.
  • Bennytwostep
6 years 4 months ago #40422 by Bennytwostep
so use the br/wh FROM THE ASD, not the PCM C1 PIN 6 BR/WH
