2019 Beetle conv roof not working after battery disconnected extended period
  • callipygian
  • callipygian's Avatar Topic Author
6 years 5 months ago #40267 by callipygian
Im working on rebuilding a car and for some reason the roof stopped opening after battery was disconnected for an extended period of time. Also when you open and close door the windows should drop maybe an inch thats no longer working either. I have vcds and when i do a capacitor discharge the windows will start working again but as soon as i do a vehicle scan the windows stop working. Any ideas?
6 years 5 months ago #40277 by Hardtopdr2
You need to do the battery relearn procedure with a capable scan tool. Or have the dealer do it if you do not.
The following user(s) said Thank You: callipygian
  • callipygian
6 years 5 months ago #40278 by callipygian
I have to do that even if its the same battery i never changed i just had it disconnected while working on car
6 years 5 months ago #40279 by Hardtopdr2
Yes because computer lost power to memory settings you will have to do a battery relearn procedure. It's a pita I know
  • callipygian
6 years 5 months ago #40280 by callipygian
I have VCDS I believe it lets me code the battery. I saw a video on youtube that speaks about it and how to do it. I will try in the morning.
  • callipygian
6 years 5 months ago #40281 by callipygian
Do the windows or the convertible top have to be relearned as well?
6 years 5 months ago - 6 years 5 months ago #40282 by Hardtopdr2
I believe so if it is not part of the battery relearn but typically it is part of it.
Last edit: 6 years 5 months ago by Hardtopdr2. Reason: Clarifying
  • callipygian
6 years 5 months ago #40283 by callipygian
Do you know where i can find info on how to do both?
6 years 5 months ago #40284 by Hardtopdr2
If your scantool can do battery relearn it will be in the same section otherwise a subscription to Mitchell or alldata will have it in there. Also note I edited my prior response as the Windows and such typically are calibrated with the battery relearn procedure.
  • callipygian
6 years 4 months ago #40343 by callipygian
When I scanned the module it shows the current battery
Time to create page: 0.322 seconds
