[FIXED] 2004 Ford Escape 3.0 V6 melted DPFE sensor
- JeffBirt
- Thank you received: 34
My first thought was excessive back pressure from a plugged cat, but I would have thought a cat that was plugged that bad would have caused drivability problems. A bit of searching the net and I found some folks had the DPFE sensor melt due to plugged cats and there was a mention that there was a known problem with the Ford DPFE sensors.
Questions: Is there known issues with the Ford OEM sensors? Since the DPFE ports are so covenant would there be any issue measuring back pressure there?
- JeffBirt
- Thank you received: 1138
I have heard of clogged cats causing this, but like you said, there's no lack of performance. Fingers crossed!JeffBirt wrote: Did some more searching and found that the two high temp silicone hoses that connect the sensor to the DPFE ports can crack causing exhaust flow over the sensor which melts it.
As far as measuring back pressure at that point, yes!
There are a couple Scanner Danner videos where he does just that.
That video Noah posted is perfect. If you don't have any excessive backpressure, then I say you're good to replace the sensor and the hoses for good measure. I've used the Dorman versions of both with no problems.
- Jeff_Birt
The upstream cats are built into the exhaust manifolds on this vehicle and each one of them is more than $500!!! The downstream is cheap by comparison at about $200.
- JeffBirt
This vehicle has two mufflers (or resonator and muffler if you prefer), has anyone ever seen on of those collapse and cause a backpressure problem?
Thanks for your help.
- JeffBirt
We pulled the rear downstream O2 sensor and got 5-6 PSI, or the same as the front downstream. This seems to point to the downstream cat (#3 cat). I tired to break loose the nuts on the front coupling of the #3 cat and not only do they not want to budge but they seem to be neither SAE or metric: 9/16" is too small, 5/8" is way to large, 14mm is too small and 15mm is a bit too large. As it is 30F out today we are working on it a bit at a time. It is supposed to be a whopping 40F tomorrow so maybe I can bet them broken loose then. I used to have a nut breaker but have not seen it in years so it might be new tool buying time
Now that you're doing after the downstream cat, I gotta tell ya, it's usually because an upstream cat fell apart and plugged the downstream. Keep your eyes open for bits of substrate.
Gotta love rusted exhaust nuts! :lol: Here's hoping the rest of the job goes smoothly for ya.
- JeffBirt
I guess the question now is: Is the problem in the 3rd cat or the resonator or muffler? The rear of the 3rd cat just has a typical muffler 'U' clamp so it should b easyish to undo and free the rear of the 3rd cat, connect the front of it and try another measurement. If I had a lift and was working inside it would likely be easier and quicker just to drill a small hole for a pressure measurement and then just weld the hole up.
I think you're on the right track with removing the downstream cat from the rest of the exhaust and rechecking your backpressure reading. I found a parts diagram that seems correct for your Escape, if I remember right:
Looks like the last place to test would be at the flange between the resonator and muffler. More rusty bolts.
- JeffBirt
JeffBirt wrote: It was the downstream cat. Pulled the resonator off of it and hooked the cat back up and the backpressure was back. Parts ordered from Rock Auto same brands as O'Reilly had, but 1/3 less cost and both parts are stainless too. All together she has about $300 in parts and a few days without her car, not too bad. Of course Dad works for free
Well that's not too bad, then! Just be sure to remind her how awesome you are for doing all this free work.
Let us know how it turns out when everything goes backtogether? Also, big thumbs up for Rock Auto, love that place.
- JeffBirt
I was thinking about the back pressure testing this morning. I think if I were to do it again I would drill a small hole in the exhaust tubing (on the side) and then plug it with a screw. My vacuum/pressure gauge cam with several small cone shaped tips so a large hole would not be required. The screw would seal it well enough and when it rusted it would be sealed permanently. If you wanted you could put some of that exhaust gasket paste on the screw. This would work if you don't have a welder or don't want to take the time to drag it out and hook it up for a 5 minute job. (I have a lot of crap in my little single car garage.)
I'm totally good with the screw reseal procedure, too. Probably would have saved some frustration with rusty nuts. But hey, at least it turned out that you had to get those loose anyway. :lol:
- JeffBirt
I tried to find some pictures of cats online as I have never had the need to swap one out before and wanted to know what they looked like inside. It seems some have 2-3 separate sections so perhaps the damage is between sections? I'm also curious as to why it failed as and why there was no CEL. The battery died on it a month or so ago and I had a scan tool on it at that time and there were no codes really other than that related to the battery being dead. I might just have to cut it apart and have a peek at the innards
