2004 Hyundai Accent Cranking No-Start
  • popoften
  • popoften's Avatar Topic Author
6 years 5 months ago #40043 by popoften
2004 Hyundai Accent Cranking No-Start was created by popoften
1.6L, auto trans. cranking no-start was intermittent, now permanent. Pulled plug wires leading back to each of the two coil packs. No spark on either. Checked for power and computer-controlled ground at inputs to the coils. Power and grounds at input good. There is also heavy corrosion in one hole on each of the two coils. Cleaned corrosion and still no spark. I am leaning toward calling the coils bad but the diagram also shows there is a condenser in the circuit. How do I test a condenser? Thx guys, Pop
6 years 5 months ago #40044 by Tyler
Replied by Tyler on topic 2004 Hyundai Accent Cranking No-Start
popoften wrote: How do I test a condenser? Thx guys, Pop
I honestly don't know. :( But I really doubt that the cause of your no start. The condenser is there for RFI/noise suppression, IIRC. If it was open, you just end up with more RFI. If it was shorted, you'd have a popped fuse.
If the power and control to each coil is good, then you're done. B) Use an incandescent test light on each, if you haven't already.
The following user(s) said Thank You: popoften
  • popoften
6 years 5 months ago #40045 by popoften
Replied by popoften on topic 2004 Hyundai Accent Cranking No-Start
Thank you, Tyler! I'll report back once repair is done!
  • popoften
6 years 2 months ago #42018 by popoften
Sorry I forgot to update. New coils fixed problem but now the cheap plastic coil input wire connects have gone bad. Will post followup question in another thread.
6 years 2 months ago #42021 by Matt T
Replied by Matt T on topic 2004 Hyundai Accent Cranking No-Start
You probably do. Condenser is the old name for a capacitor, which has stuck around in automotive terminology way longer than it did anywhere else.
