12v on signal wire
  • alphayed
  • alphayed's Avatar Topic Author
6 years 5 months ago #40031 by alphayed
12v on signal wire was created by alphayed
I was working on t CAT C15 engine that had a code for the oil pressure sensor voltage high. I check the pins and I have 5v supply, ground and 12v on the signal with the sensor unplugged. I ground the signal and the ECM respond with voltage low code so I replace the sensor the it fixed the problem. My question is, why does the signal wire goes to 12v with sensor unplugged? I was expecting zero volts. Is that an example of bias voltage, because the 12v would not light up my test light either.
6 years 5 months ago #40032 by Tyler
Replied by Tyler on topic 12v on signal wire
Definitely sounds like a case of bias voltage to me. That kind of detection logic is exactly the same thing we see on passenger cars and light duty trucks.
Was there an associated gauge or data PID? Might have been fun to install a variable resistor and see if you could manipulate the signal into something rational.
  • alphayed
6 years 5 months ago #40052 by alphayed
Replied by alphayed on topic 12v on signal wire
I will definitely play around with more the next time I run into it. I am just surprised to see that on a 5v reference circuit.
