P0538
- autojoe
- Thank you received: 7
6 years 5 months ago #39993
by autojoe
P0538 was created by autojoe
2004 Ford taurus 3.0u ac not working code for evaporator discharge temperature sensor voltage high. It has the sensor but pin 66 at pcm is empty. Pinched into alldata 2004 to 2006 models says on 2005 model early build has it but later build does not and 2006 does not have it. This is a 10 Vin is 4 for 2004 but pin 66 is empty with code p0538 and has the thermistor in evap box. It does have the pin 91 signal return wire at pcm for the thermistor. Can someone explain where the tan orange wire goes to. Please help
6 years 5 months ago - 6 years 5 months ago #39999
Replied by Noah on topic P0538
I've gotta ask because I deal with it all the time, 10th digit off the dash VIN plate?
Not the door.
Also, pushrod 3.0 or duratec 24v 3.0?
Also, also... Manual or automatic climate control?
Not the door.
Last edit: 6 years 5 months ago by Noah.
- autojoe
6 years 5 months ago #40010
by autojoe
Replied by autojoe on topic P0538
4
- autojoe
6 years 5 months ago #40011
by autojoe
Pushrod 3.0
6 years 5 months ago #40026
Thank you for clarifying. You wouldn't believe how many issues I see from people misidentifying the year.
I don't see why pin #66 would be empty on your PCM
Is it flanked by a brown & green and a Violet & white wire?
65: EGR DPFE sensor- brown/lt green
66: Evap temp sensor- tan/orange
67: canister vent - violet/white
The following user(s) said Thank You: autojoe
- Cheryl
- Thank you received: 215
6 years 5 months ago #40051
by Cheryl
Replied by Cheryl on topic P0538
Is the wire your looking for on the connector but just no pin for it on the pcm?? If so somebody might be trying to pull a quick one on ya wrong year pcm.
- autojoe
6 years 5 months ago #40223
by autojoe
Thanks Cheryl missing at pcm. Found out engine swap.
- autojoe
6 years 5 months ago #40224
by autojoe
