[Fixed!] 1998 Nissan Frontier with KA24DE -- Temp Gauge
6 years 5 months ago #40232 by John Clark
Replied by John Clark on topic 1998 Nissan Frontier with KA24DE -- Temp Gauge
So, it's apparent whatever is going on is being caused by the temp sensor. One thing to remember is that new doesn't mean good. Where did you get the sensor? Most auto parts sell junk electrical parts that are often bad right out of the box.
At this point it appears that either the sensor is bad or there is something going on inside the manifold that is causing the sensor to indicate full hot, or short out.
I suggest getting a good quality replacement, either OE or Wells (WVE.) A little known secret is that Autozon's Duralast brand is often Wells reboxed under the Duralast name. Those are the only electrical parts I'll buy at the parts stores.
As for the scan tool, any OBDII scan tool that supports live data should be able to see the coolant temp. The reason you couldn't get the Modis to talk with the vehicle is that you likely were connected to the normal 16pin OBDII DLC. There is another diagnostic port, usually found under the dash or in the fuse box. It takes a proprietary Nissan connector but the Modis should talk to it if he has the Nissan connector for it. I have to use this on my 98 200SX. In the early days of OBDII they were still using their proprietary diagnostic connectors in addition to the OBDII.
  • JimT
  • JimT's Avatar Topic Author
6 years 5 months ago #40233 by JimT
I got the sensor from a Nissan dealership. Nissan part. I thought that since the sensor acted properly so far (when I could ohm it, it has checked out so far, but I haven't yet caught it when it was reading hot) and that it went cold when I unplugged it (showing me it's not necessarily shorting), that the sensor was looking good and evidence was pointing to me having air in the system or something similar.
Good information about the extra diagnostic port. I have seen something similar on a 1999 BMW. Something about the changeover from OBD1 to OBD2. I'll look into it. We were connected at the 16 pin "regular" DLC, so I'll look for the other one. I doubt he has the connector for it, though, but I'll check.
6 years 5 months ago #40235 by John Clark
See this video for the Nissan diagnostic port. In the first 20 seconds of this video you can see it in the fuse box, below all the fuses.
6 years 5 months ago #40237 by John Clark
As for this issue, I'm at a loss. Have you been able to do the gauge sweep self diagnostic while it is acting up? This seems to be an intermittent so you have to be able to test while it's acting up. If you test the gauge sweep while it's working you really don't get a good test out of that.
I would also like to measure the voltage on the sensor wire while it's acting up, as well, and compare it to when it's working normally.
6 years 5 months ago #40240 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 1998 Nissan Frontier with KA24DE -- Temp Gauge
To me it looks more like a open in the wiring than anything else.
6 years 5 months ago #40243 by John Clark
But an open would cause the gauge to go full cold, just as it does when he unplugs it. To fail full hot needs a short.
I was thinking possibly a short near or in the cluster but that wouldn't explain why when it happens he can unplug the sensor and it goes full cold.
Possibly a bad power or ground to the gauge but I would think that would affect the other gauges since they share power and ground.
I'm thinking chafed wire somewhere that's shorting and moves when the connector is pulled off.
6 years 5 months ago #40244 by Matt T
I agree with John on intermittent short to ground which gets disturbed when the sensor is unplugged being a possibility. Wiggle test with the sensor connected and an assistant watching the gauge will probably find that.
I'm guessing this gauge is a simple voltage divider circuit with R1 in the cluster and R2 being the temp sensor, with the gauge measuring the voltage between R1 and R2. So the less likely, but does fit the symptoms, cause is an intermittent high resistance on the R1 side. When R1 increases R2 will pull the voltage down and when R2 is unplugged the gauge sees full voltage. If that is what's happening I can't think of an easy way to diag it conclusively....
6 years 5 months ago #40245 by John Clark
To rule out something in the gauge cluster I'd unplug it and drive it with the gauge on full cold and see if it acts up. If it doesn't act up when unplugged then one can only assume it's not an issue in the gauge cluster.
6 years 5 months ago #40246 by John Clark
Because this is not going to be an easy one I downloaded the actual 98 Frontier manual from Nicoclub. Here are the actual diagrams for this truck. I think my attention would be at the harness and the connectors. Looks like there is a connector inside the cab, over on the passenger side under the dash. Maybe it's got some water or corrosion in it? Just trying to come up with something we've missed. You're close on this one, just need to get a few more checks in while it's acting up. The intermittent nature of it can make it difficult.
6 years 5 months ago #40247 by John Clark
Matt T wrote: ... So the less likely, but does fit the symptoms, cause is an intermittent high resistance on the R1 side. When R1 increases R2 will pull the voltage down and when R2 is unplugged the gauge sees full voltage. If that is what's happening I can't think of an easy way to diag it conclusively....
Assuming this is the issue, it would be in the gauge cluster. Some tapping on the gauge cluster might help. A few posts back, I suggested taking a voltage measurement at the sensor connector but I suggested taking it unplugged which probably wouldn't yield any results (no current flow, no voltage drop across R1.) Would it help to take a voltage measurement at the sensor connector while plugged in and compare during failure and during normal operation?
You might be able to find a used cluster and plug it in and see if the symptoms change.
6 years 5 months ago #40248 by John Clark
This is a bit anecdotal but I have a neighbor who has a 97 Pathfinder which is why I had the Pathfinder manual at the ready earlier in the thread. His tach reads 8,000 rpm most of the time. I haven't spent any real time diagnosing that for him but I did notice that tapping on the gauges did yield changes in the needle, leading me to suspect a bad gauge cluster on that one. While not the same truck, I'm sure it's similar.
6 years 5 months ago #40254 by Matt T
John Clark wrote: Assuming this is the issue, it would be in the gauge cluster. Some tapping on the gauge cluster might help. A few posts back, I suggested taking a voltage measurement at the sensor connector but I suggested taking it unplugged which probably wouldn't yield any results (no current flow, no voltage drop across R1.) Would it help to take a voltage measurement at the sensor connector while plugged in and compare during failure and during normal operation?
Agreed on testing voltage unplugged. Not near enough current flow with a 10 meg ohm DMM. Testing voltage with a fairly high resistance to ground might work. Would need to experiment to find a resistor which draws just enough current to pull the voltage down slightly. Then test when the fault appears to see if the resistor pulls the voltage lower than normal. Or if the OP has a DMM with a low impedance mode that might be enough to load the circuit.
  • JimT
6 years 4 months ago #40677 by JimT
First off... you guys are excellent. I don't know what else to say. Secondly, a status update... I have been riding around with my multimeter in my truck. Whenever it pegs hot, I stop, jump out and ohm the sensor. Originally, the sensor would ohm at 120-130 ohms, which would be normal temp and should not have the gauge reading hot. When I put the connector back on, the gauge always goes back to normal. BUT, lately when I jump out and ohm it, I've gotten as low as 60 ohms on the sensor. THAT would show hot on the gauge, I think. It's right down about where the coolant would be reading 212 F. Bottom line, I'm still stumped. I've also had readings where I jump out and as I'm ohming the sensor, the resistance is climbing from low to high, as in I can literally watch it climb on the meter.
I had seized on the idea of using the scan tool to read the other sensor (the one the ECU uses) to compare the two, hence my silence lately. The two sensors are right next to each other, so in theory they should read the same temperature. After you guys showed me where the proprietary connector was, I thought "Wow. Been there the whole time and I never knew it." The Nissan 2 adapter needed to connect was on backorder, so I'm waiting for that to show up. Once I can talk to the other sensor, I'll report back in. Thanks again, folks. This issue is not the end of the world, I just want to solve the riddle, whether it's the sensor, wire, gauge, or if it's actually getting hot!
6 years 4 months ago #40678 by Hardtopdr2
Replied by Hardtopdr2 on topic 1998 Nissan Frontier with KA24DE -- Temp Gauge
One thing I just thought of us when was the last time the coolant was flushed and changed? If you don't remember buy a antifreeze tester. They are cheap and you can eliminate antifreeze as a possible cause. The other would be a sticking thermostat. Which I have run into a time or two. Also some millimeters are sold with a temperature test lead which you could put on same area as coolant sensor to see if sensor is reading correctly.
Just a thought
  • JimT
6 years 4 months ago #40679 by JimT
Antifreeze was changed about a year ago when the service place replaced the thermostat. I have seen the multimeters with the temp probe as well... may end up with one before it's over.
  • JimT
6 years 4 months ago - 6 years 4 months ago #40854 by JimT
So, put the scan tool on it and read the Engine sensor. It never moved off of 181 degrees F. While it unwaveringly sat on 181 degrees, the gauge read full hot, then after a while returned to normal. Conclusion? Pretty sure the truck is telling me it's not hot.
It's the gauge, right? That makes sense, but here's what I don't understand... while the gauge read hot, I ohmed that sensor. It read 47 ohms. That is low resistance and a reading that I would expect the gauge to register as hot. Why is the sensor reading such a value? I check the resistance by putting the positive lead on the sensor and the negative lead on the battery negative.
Pics of the scan tool and gauge are below.
Last edit: 6 years 4 months ago by JimT. Reason: Add pictures
  • JimT
6 years 4 months ago #40855 by JimT
Gauge while scan tool at 181
6 years 4 months ago #40858 by John Clark
47 ohms shouldn't read full hot. That's about 212F which is getting pretty warm but not full hot, I wouldn't think.
It is looking more like an issue in the gauge circuit itself, likely in the cluster. Have you tried tapping on the gauge cluster when it's reading full hot?
The following user(s) said Thank You: JimT
  • JimT
6 years 4 months ago #40859 by JimT
Okay... good to know. I haven't tried tapping on it, but will do so and see if it reacts. It doesn't look too bad to remove the cluster. Think the next step would be to take it out and look for bad solder joints? Or potentially send it to a cluster repair place?
6 years 4 months ago #40866 by Hardtopdr2
I don't suppose you checked your two grounds for the dash m14, m68 have you? One is on drivers side front footwell the other is on the pass side door jamb under dash in your diagrams. These two spots can develop corrosion from windshield leaks etc. Would not hurt to check those for the green monster. Take them off and clean them as those are the cluster grounds from the guages.
Time to create page: 0.495 seconds
