[FIXED] 14 hyundai sonata comm issue
  • bandrauto
  • bandrauto's Avatar Topic Author
6 years 5 months ago #39766 by bandrauto
14 hyundai sonata comm issue was created by bandrauto
ive got a 2014 hyundai sonata, no communication with the abs module. ive load tested the grounds and powers. the CAN lines to the module seem to be good, no erratic signal or high or low voltage. my question is, can i cut the pair coming out of the abs unit and test to see if the module is putting out the proper signal? if so, what could i expect if the module was good.
6 years 5 months ago #39769 by Cheryl
Replied by Cheryl on topic 14 hyundai sonata comm issue
Have you checked the pins 6 and 14 at the data link connector for 60 ohms battery unhooked. If you have 60 ohms the data lines are not the issue. But you could do what you wanted if ya can repair the wires when your done
6 years 5 months ago #39771 by Tyler
Replied by Tyler on topic 14 hyundai sonata comm issue
Have you tried a soft reset? Or tried disconnecting the ABS module and leaving it disconnected for awhile?
I've had success with this method on other Hyundai products in the past, and it has restored communication to dead modules.
Worth a try. :)
6 years 5 months ago #39782 by Cheryl
Also make sure you check pin figment in the connector
  • bandrauto
6 years 5 months ago #39784 by bandrauto
Replied by bandrauto on topic 14 hyundai sonata comm issue
good ohms at dlc. i figure the module is actually not communication, there didn't seem to be anything dragging it down. carlot got a used unit and i plugged it in before swapping and i got back communication. thank you everyone for you replies.
