2005 Subaru wrx misfire
  • Empowered
  • Empowered's Avatar Topic Author
9 years 8 months ago - 9 years 8 months ago #5270 by Empowered
2005 Subaru wrx misfire was created by Empowered
Hi guys thought maybe I'd ask here for some help I have a 2005 wrx stock motor with some bolt ons. The cars is giving misfire in cylinder 2 and 4 and also o2 sensor code. It's not muffing smoke or shaking the car horridly. It's noticeable but barley shakes engine a bit.
Things ive don't are cleaned MAF sensor, new air filter and checked cylinder 2 coil pack and spark plug. The spark plug seems good no oil or fuel.
Mods are
Vf39 sti turbo
Sti pink injectors
Sti intercooler
Cobb turbo back exhaust
Also have boost gauge and at idle seems constant and doesn't bounce like if it had a boost or vacuum leak
Last edit: 9 years 8 months ago by Empowered.
9 years 8 months ago #5275 by matt.white
Replied by matt.white on topic 2005 Subaru wrx misfire
What tool access do you have? Can you do a relative compression test? I've heard of Subaru valve guides moving and causing sealing issues but not sure it effects the wrx motor. Another thought is confirm valve timing. From memory 2 and 4 are the same side? I'm wondering if someone has done a belt and that's effecting one bank.
9 years 8 months ago #5277 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2005 Subaru wrx misfire
With a 2 cylinder misfire on the same bank you really have to look to possible causes that are common to both cylinders. Also keep in mind misfire counters can point to the wrong cylinders.
As Matt.white has said a compression test might be a good move, depending on access to the spark plugs and tools available an ordinary compression gauge test or a cylinder leak down would be my choice.
A leak down test is the best compression for pin pointing what parts are causing any loss of compression.
I have never done the cam belts one of these but I do know the cam timing can be tricky to set up but my thinking keeping in mind this is a modified engine is valve seat recession or a head gasket issue.
What O2 sensor codes are you getting ? lean O2 senors codes are often just a sign of misfire due to other causes or it could point to a genuine lean condition causing the misfire. Diagnosing based on codes alone can bite back you need to look at live data prefferably in a graph form , focusing on O2 sensor, fuel trims, and MAF output Don't be too quick to rule out a vacuum leak.
9 years 8 months ago #5289 by Tyler
Replied by Tyler on topic 2005 Subaru wrx misfire
I'm with Andy and Matt about a possible timing issue on bank two. If the outside timing covers are easily removed, then it may be easiest to just pull them and manually check the marks.
  • Empowered
9 years 8 months ago #5298 by Empowered
Replied by Empowered on topic 2005 Subaru wrx misfire
I don't have tools to do a compression test I think I am going to check my driver side timing marks for intake and exhaust cams if they are off I'm going to move them to proper markings. Hopefully that's my problem
9 years 8 months ago #5319 by dansim
Replied by dansim on topic 2005 Subaru wrx misfire
swap the coils from no 2cyl to no 3 clear codes test drive and see if it changes the codes to a diff cylinder and maby put some new plugs in depends on how worn the tips are .
9 years 8 months ago #5328 by fudgie
Replied by fudgie on topic 2005 Subaru wrx misfire
I'm sure you already know that those engines need a solid tune when you turn the wick up. They do not like any detonation and easily break ring lands. I would start with a compression test and move forward from there. Sorry to be a "Debbie downer" but I have been down this road many times. Goodluck!
  • Empowered
9 years 8 months ago #5360 by Empowered
So update I didn't look at timing garage was full. But I did scan the car again and I got only 1 fault now code po420 Catalytic System Efficiency Below Threshold (Bank 1)
And today I started it to move the car and it didn't misfire at all
9 years 8 months ago #5361 by Andy.MacFadyen
Are you using a cold air intake or K&N style filter?
  • Empowered
9 years 8 months ago #5362 by Empowered
That car came with the stock air box but had a high performance air filter from Cobb I removed it and put a normal air filter and cleaned the MAF
