Mercedes ml500 cam / crank waveform 2003
- ChrisG
- Thank you received: 1138
I see some people have viewed you post, but no one seems to have that waveform yet. Bummer, I don't have it either.
Nothing from Google, Alldata usually doesn't provide this info (and this case is no exception). I'm not a sponsoring member of IATN, so I don't have access to the waveform library.
Someone around here should be able to help with that.
Can you take a screen capture of the waveforms and post them up here as a PNG or something?
- ChrisG
Make sure to check out the posting guide for pictures Here .
I suspect the files are just too large.
- ChrisG
- ChrisG
- ChrisG
Choose the pic you want to upload
Click "Insert"
Then when you're all done, submit.
- ChrisG
- ChrisG
- ChrisG
IT WORKS !!!!!! THIS IS THE RELATIVE COMPRESHION WAVEFORM WITH NO1 IGN FIRING ORDER IS 15486372
THIS IS A RENAULT CLIO 09 1.2 SAME TEST BUT A 4 CYLINDER . NOT SURE IF IT WILL BE CLEAR ENOUGH SINCE I RESIZED PIC BUT ON THE ML500 WAVEFORM THE SPARK EVENT ON 1234 ARE ALL BEFORE THE PEAK ABOUT 6 TO 8 DEG YET 5678 ARE NEAR AS BANG ON ,THE PICK MAY NOT SHOW THE 8 X90DEG LINES
- ChrisG
ChrisG wrote: AFTER HAVING A BETTER LOOK MY TIMING IS OFF !IF YOU MOVED YOUR GREEN CAM ALONG TO TOUCH THE YELLOW TRACE THIS IS HOW MY WAVEFORM LOOKS ,MY GREEN CRANK IS YOUR BLUE AND THE TRAILING EDGE OF THE SINK IS NEARLY IN THE MIDDLE OF YOUR CAM BUT ON MINE ITS ABOUT A 1/3 . THATS GREAT NEWS THANKYOU
Is that great news? :huh: :lol: Most aren't so happy to find a timing problem, but I'm happy that you're happy!
Thinking about a jumped chain?
Tyler wrote: Late to the party, sorry guys! I found something on iATN:
There's not much info to go with this capture, but I'd guess that the red and blue traces are both wires on the CKP, and the green trace is the CMP. Yellow is an ignition sync, probably cylinder #1?
Hope this helps.
Do you think the fluctuations in the A/C signal indicate that this was a cranking capture?
Noah wrote: Do you think the fluctuations in the A/C signal indicate that this was a cranking capture?
Maybe? ChrisG's waveform shows the same oscillations... Good eye, sir!
Now I'm looking closer at the CKP signal... this is a V8, right? So, there should be eight points in 720 degrees where the engine 'slows down' to run a cylinder through it's compression stroke.
I only count six? I'm not saying Chris is missing compression on two cylinders, I'm saying I can't be looking at this right. :lol:
- ChrisG
Yeah, good eye. That's hard to justify...
Even the known good has only 6 of those "events" per 720 degrees of rotation
ChrisG wrote: Great news that it's what I suspected from the other waveform ,oh and it's not my car it's my brothers ! Know if it was on my car I would be deep in trouble that would be engine out
Ooooooh OK, gotcha! Well, let him worry about it then, right? :lol:
- ChrisG
