dead cylinder 1988 22re
- Christian77
6 years 6 months ago #39221
by Christian77
dead cylinder 1988 22re was created by Christian77
i have a toyota 1988 22re head gasket was replaced and after everything was all ready to go started up and once it ran for a bit it had a misfire
cheked for spark on all cylinders and it was there firing order is 1-3-2-4 the only cylinder with a change was number 1 it dint run any difrent
i checked the wire the spark plug so then my concern was fuel so i plugged the scope in and it acted as if it had fuel delivery problems so i went after the injectors i conected the scope and there was mechanical movement but i replaced the number one injector just because i though maybe its clogged
compression was good about 180 i did not check the other cylinders could one tooth of on the timing do this no contribution at all?
i also made sure the fuel was getting to cylinder valve opens all the way.
any ideas thanks.
any ideas thanks.
- Cheryl
- Thank you received: 215
6 years 6 months ago #39225
by Cheryl
Replied by Cheryl on topic dead cylinder 1988 22re
Did you also perform a leak down test? Was the head redone or just head gasket? I’d definitely check timing because I did a timing belt on a newer Toyota and off one tooth it actually cut spark off to number 6 coil.
6 years 6 months ago #39227
I second the leak down test for this one.
Replied by Noah on topic dead cylinder 1988 22re
I never would have expected that! Good to know.Cheryl wrote: Did you also perform a leak down test? Was the head redone or just head gasket? I’d definitely check timing because I did a timing belt on a newer Toyota and off one tooth it actually cut spark off to number 6 coil.
- jreardon
- Thank you received: 198
6 years 6 months ago #39229
by jreardon
Replied by jreardon on topic dead cylinder 1988 22re
firing order is 1342 i think
- Christian77
6 years 6 months ago #39232
by Christian77
Replied by Christian77 on topic dead cylinder 1988 22re
I have not done a leak down test but I think I'll definitely try it and another thing that's on my mind maybe valves are too tight and yes the whole head was sent to the mechine shop
