2004 e46 n46 mv9n46 dme changed dme same errors
  • Carlhadenuff
  • Carlhadenuff's Avatar Topic Author
6 years 7 months ago - 6 years 7 months ago #38628 by Carlhadenuff
had car about a year done vavle stem seals had issus befor this thourt to be headgaskit witch was all so skimmed and all new parts
i do have a nother post ill link it at end just done a code read today after putting the fuel pump relay in right place seems to be starting to make sense now as error were really random and was cutting out the dme above 3,000 rpm now it dont rev above 2,000 rpm here are errors
2D0F DME: Hot-film air-mass sensor, signal mev9n46 Engine electronics
2C9C DME: Oxygen-sensor heater before cat. 1 mev9n46 Engine electronics
2B5D DME: Crankshaft sensor mev9n46 Engine electronics
2A88 DME: Exhaust VANOS 1 mev9n46 Engine electronics
2A69 DME: Valvetronic, voltage supply, servomotor 1 mev9n46 Engine electronics
2EE0 DME: Engine temperature sensor, signal mev9n46 Engine electronics
2CF8 DME: Throttle-valve potentiometer mev9n46 Engine electronics
2CF9 DME: Throttle-valve potentiometer 1 mev9n46 Engine electronics
2CFA DME: Throttle-valve potentiometer 2 mev9n46 Engine electronics
2A67 DME: Valvetronic, internal fault mev9n46 Engine electronics
E R R O R M E M O R Y
Date: 23.03.2020 10:04:15 ECU: MEV9N46 JobStatus: OKAY Variant: MEV9N46
RESULT: 10 error in error memory
air mas sensor not plugged in -39.75 degree
new crank sensor
new vvt motor (chaina :)
new exshast vanos and solenoids (yes x2)
new engine temp sensor (euro)
new lambda and same reading when unplugged
these 3 are intersting as ive changed most over error parts
2D0F CDKLM - Heissfilmluftmassenmesser
P0102 Air mass or air flow rate 1 - Low input
Error counter: 1 Logistic counter: 39
Mileage 226550 km
Engine speed (nmot) 1160.00 /min
Intake air temperature (tans) -39.75 degree C
angle DK z. on DK connection (wdkba) 3.14 %
DK ADC HFM (adhfm) 0.00 V
Signal below threshold or short circuit after minus test conditions sumupts errors currently present and already saved errors would not cause a warning lamp to light up diagnostics actively -- -- -- -- --
Error code: 2D 0F 62 01 01 02 01 27 58 7F 1D 0B 08 00 FF FF FF FF FF FF FF FF FF FF FF FF
2C9C CDKHSVE - power amplifier heating probe in front of catalyst
Mileage 226550 km
Voltage LS-Heating by Kat (uhsv) 2.87 V
Time after start (tnse_u) 0.00 s
Supply voltage (ub) 4.52 V
unknown environmental condition 76.00 1
no signal or value test conditions sum up errors currently present, but not yet saved (debounce phase) Errors would cause the lighting of a warning lamp diagnosis to be active -- -- -- -- --
Error code: 2C 9C C4 01 00 00 01 27 58 7F 93 00 30 4C FF FF FF FF FF FF FF FF FF FF FF FF
2B5D CDKBM - Bezugsmarkengeber
Error counter: 1 Logistic counter: 40
Mileage 226550 km
Engine Speed (nmot) 0.00 /min
Engine Temperature (tmot) 84.75 Degrees C
Ambient Temperature (tumg) 6.00 Grd C
Supply Voltage (ub) 12.15 V
Crankshaft tooth defect or luecken loss test conditions satisfies errors currently present, but not yet saved (debounce phase) Errors would cause the lighting of a warning lamp to actively -- -- -- -- --
Error code: 2B 5D C8 01 00 00 01 28 58 7F 00 B1 48 81 FF FF FF FF FF FF FF FF FF FF FF FF
2A88 CDKANWS - Camshaft control outlet
P0014 Camshaft Control Outlet (Bank 1) - Adaptation Value Early Position Implausible or Performance Problem
Mileage 226550 km
Engine speed (nmot) 0.00 /min
Engine temperature (tmot) 84.75 degrees C
relative air filling (rl) 84.00 %
Supply voltage (ub) 11.30 V
Stop adaptation outside of normal area test conditions sumupts errors currently present and already saved errors would not cause a warning lamp to light up diagnostics actively -- -- -- -- --
Error code: 2A 88 62 01 00 14 01 28 58 7F 00 B1 70 78 FF FF FF FF FF FF FF FF FF FF FF FF
2A69 CDKDVULV - VVT-Leistungsversorgung
P1057 VVT supply voltage actuator (bank 1) - electrical fault
Mileage 226550 km
Supply voltage (ub) 14.04 V
Actual value Eccentric angle VVT 180.00 degree
voltage VVT relay 11.64 V
Byte-oriented storage for B_vvt in FF array 1.00
Relay error test conditions satisclosed errors currently present and already saved errors would cause the light of a warning lamp to actively cause diagnosis -- cycle flag set -- MIL on --
Error code: 2A 69 E8 15 10 57 01 28 58 7F 95 E1 95 01 FF FF FF FF FF FF FF FF FF FF FF FF
2EE0 CDKTM - Temperature-controlled motor cuehlmittel
Mileage 226550 km
Motortemp.-Ersatzwert aus Modell (tmew) 60.00 Grd C
Ansauglufttemperatur (tans) -39.75 Grad C
Motordrehzahl (nmot) 0.00 /min ADC TM (adtm) 5.00 V
Short-circuit after plus or line interruption Test conditions sum up errors currently present, but not yet saved (debounce phase) Errors would cause the lighting of a warning lamp to actively cause diagnosis -- -- -- -- --
Error code: 2E E0 C2 01 00 00 01 28 58 7F 90 0B 00 FF FF FF FF FF FF FF FF FF FF FF FF FF
2CF8 CDKDK - DK-Potentiometer
Mileage 226550 km
angle DK on DK connection (wdkba) 100.01 % DK
Voltage DK-Poti1 (udkp1_u) 0.06 V
Voltage DK-Poti2 (udkp2_u) 0.18 V
Error DK-Poti 1 or DK-Poti 2 test conditions sumupts errors currently present, but not yet saved (debounce phase) Error would cause the light of a warning lamp to actively cause diagnosis -- --Error code: 2C F8 C8 01 00 00 01 28 58 7F 00 FF 03 09 FF FF FF FF FF FF FF FF FF FF FF FF
2CF9 CDKDK1P - Drosselklappenpoti 1
Mileage 226550 km
Setpoint DK on lower connection (wdks) 1.95 %
Ambient Temperature (tumg) 9.00 Grd C
Area violation Poti down test conditions sumbs errors currently present, but not yet saved (debounce phase) Error would cause the lighting of a warning lamp to actively -- -- -- -- --
Error code: 2C F9 C2 01 00 00 01 28 58 7F 00 05 4C 09 FF FF FF FF FF FF FF FF FF FF FF FF
2CFA CDKDK2P - Drosselklappenpoti 2
Mileage 226550 km
Voltage DK-Poti1 (udkp1_u) 0.02 V
Error code: 2C FA C2 01 00 00 01 28 58 7F 00 05 4C 01 FF FF FF FF FF FF FF FF FF FF FF FF
2A67 CDKDVEST - VVT control
P1050 VVT control (bank 1) - malfunction
Mileage 226550 km
Supply voltage (ub) 11.02 V
Voltage Diagnostic port VVT- Control 1.46 V
Temperature VVT- Power stage 19.00 degrees C
Short circuit of motor line test conditions sumupts errors currently present and already saved errors would cause the lighting of a warning lamp to cause diagnosis active -- cycle flag set -- MIL one --
Error code: 2A 67 E8 15 10 50 01 28 58 7F 00 75 4B 13 FF FF FF FF FF FF FF FF FF FF FF FF ===================================================
www.scannerdanner.com/forum/post-your-re...6-318-ci-n46b20.html
first post
Last edit: 6 years 7 months ago by Carlhadenuff.
6 years 7 months ago #38639 by jreardon
Did all these codes come all at once? If so, I notice the iat and ect is showing as unplugged or missing a ground. Pick a simple circuit and chase it to unravel this mess. Is this car on www.newtis.info/ because my eyes cross when i stare at so many model names and engine names :(
The following user(s) said Thank You: Carlhadenuff
  • Carlhadenuff
6 years 7 months ago #38641 by Carlhadenuff
Replied by Carlhadenuff on topic 2004 e46 n46 mv9n46 dme changed dme same errors
jreardon wrote: Did all these codes come all at once? If so, I notice the iat and ect is showing as unplugged or missing a ground. Pick a simple circuit and chase it to unravel this mess. Is this car on www.newtis.info/ because my eyes cross when i stare at so many model names and engine names :(
thanks for your replay im a bit new to all this yes all the error come when i start car maybe 4 or 5 with key on engine off can u explain IAT and ECT what is this sort for ?? and yes its on tis www.newtis.info/tisv2/a/en/e46-318ci-cab/
kind regads
carl
6 years 7 months ago #38642 by jreardon
I think the ect would be easier since it's probably just two wires to deal with. With the key on, unplug the sensor and one of the two wires should have something around 5 volts. Next plug it back in and check the voltage on the other wire by backprobing it, it should be 0. If you read 5v on both wires with the sensor plugged in you have a bad ground or ground wire somewhere.
  • Carlhadenuff
6 years 7 months ago - 6 years 7 months ago #38648 by Carlhadenuff
just been out to the car and changed the vvt sensor but got this hard error that will not clean
its 2a67 and 2a69
Date: 26.03.2020 12:53:38 ECU: MEV9N46 JobStatus: OKAY Variant: MEV9N46
RESULT: 2 error in error memory
2A67 CDKDVEST - VVT-Ansteuerung
Mileage 226550 km
Versorgungsspannung (ub) 10.83 V
Spannung Diagnose-Port VVT- Ansteuerung 1.46 V
Temperatur VVT- Endstufe 25.00 Grad C
Kurzschluss der Motorleitung Testbedingungen erfuellt Fehler momentan vorhanden, aber noch nicht gespeichert (Entprellphase) Fehler wuerde das Aufleuchten einer Warnlampe verursachen Diagnose aktiv -- Zyklus-Flag gesetzt -- -- --
Error code: 2A 67 C8 05 00 00 01 28 58 7F 00 73 4B 19 FF FF FF FF FF FF FF FF FF FF FF FF
Mileage 226550 km
Istwert Exzenterwinkel VVT 50.40 Grad
Spannung VVT- Relais 9.38 V
Byteorientierte Ablage fuer B_vvt im FF- Array 1.00
Relaisfehler Testbedingungen erfuellt Fehler momentan vorhanden, aber noch nicht gespeichert (Entprellphase) Fehler wuerde das Aufleuchten einer Warnlampe verursachen Diagnose aktiv -- Zyklus-Flag gesetzt -- -- --
Error code: 2A 69 C8 05 00 00 01 28 58 7F 73 3F 78 01 FF FF FF FF FF FF FF FF FF FF FF FF =============================================================
  • Carlhadenuff
6 years 7 months ago #38649 by Carlhadenuff
its unplugged
  • Carlhadenuff
6 years 7 months ago #38655 by Carlhadenuff
Date: 26.03.2020 13:50:45 ECU:
RESULT: 4 error in error memory
P1050 VVT-Ansteuerung (Bank 1) - Fehlfunktion
Mileage 226550 km
Kurzschluss der Motorleitung Testbedingungen erfuellt Fehler momentan vorhanden und bereits gespeichert Fehler wuerde das Aufleuchten einer Warnlampe verursachen Diagnose aktiv
-- Zyklus-Flag gesetzt -- MIL ein --
Error code: 2A 67 E8 15 10 50 01 28 58 7F 00 73 4B 19 FF FF FF FF FF FF FF FF FF FF FF FF
P1057 VVT-Versorgungsspannung Stellmotor (Bank 1) - elektrischer Fehler
Mileage 226550 km
Relaisfehler Testbedingungen erfuellt Fehler momentan vorhanden und bereits gespeichert Fehler wuerde das Aufleuchten einer Warnlampe verursachen Diagnose aktiv -- Zyklus-Flag gesetzt -- MIL ein --
Error code: 2A 69 E8 15 10 57 01 28 58 7F 73 3F 78 01 FF FF FF FF FF FF FF FF FF FF FF FF
2A6B CDKDVPMN - Leistungsbegrenzung VVT-Notlauf
P1062 VVT-Notlaufanforderung (Bank 1) - Vollhubposition nicht erreicht
Error counter: 4 Logistic counter: 40
1. Umweltsatz Mileage 226550 km
Spannung VVT- Relais 7.89 V
Motorstrom VVT 0.00 A
Tastverhaeltnis VVT- Motoransteuerung 0.00 %
2. Umweltsatz Mileage 226550 km
Spannung VVT- Relais 10.31 V
Motorstrom VVT -1.56 A
3. Umweltsatz Mileage 226550 km
Spannung VVT- Relais 5.94 V
Exzenterwinkel faehrt nicht auf Vollhub Testbedingungen erfuellt Fehler momentan vorhanden und bereits gespeichert Fehler wuerde das Aufleuchten einer Warnlampe verursachen Diagnose aktiv -- Zyklus-Flag gesetzt -- MIL ein --
Error code: 2A 6B E2 15 10 62 04 28 58 7F 65 00 3F 00 58 7F 84 FF 3F 00 58 7F 4C FF 3F 00
P0102 Luftmassen- oder Luftmengendurchsatz 1 - Input niedrig
Mileage 226550 km
Motordrehzahl (nmot) 1360.00 /min
Winkel DK bez. auf DK-Anschl. (wdkba) 4.31 %
Signal unterhalb Schwelle oder Kurzschluss nach Minus Testbedingungen erfuellt Fehler momentan vorhanden und bereits gespeichert Fehler wuerde kein Aufleuchten einer Warnlampe verursachen
Error code: 2D 0F 62 05 01 02 01 28 58 7F 22 0B 0B 00 FF FF FF FF FF FF FF FF FF FF FF FF =============================================================
