Subaru 2013 Impreza wrx sti hatch crank no start
jeremy.lishman
Offline
New Member
Thank you received: 0
6 years 7 months ago #38391
by jeremy.lishman
Maybe someone can provide direction for me. 2013 sti, has spark, cranks, injector pulse, triple checked timing no start.
Tach is not working however scan tool shows rpm at 200 during cranking.
Coolant temp sensor is also not showing in dash as if it is missing.
The car previously ran so do not think has compression issue. Timing teeth are per factory manual.
Tried two batteries fully charged.
Direction anyone?
Thanks in advance
Tyler
Offline
Moderator
Full time HACK since 2012
Thank you received: 1551
6 years 7 months ago #38392
Previous to what? :huh: Any relevant repair history?
Scan tool RPM is definitely a good sign. Any stored trouble codes?
Fuel pressure is unlikely, and a pain to check on these engines. :silly: Will it run if you give it some alternate fuel in the intake tube?
Thank you received: 1037
6 years 7 months ago #38398
Giving it propane or carb cleaner in the intake was my thought also thinking fuel delivery or misfueled (diesel or water in tank)
Time to create page: 0.254 seconds
