2003 F150 4.6 VIN 6 bank 1 sensor 1 pegged rich
  • DigorDiePerformance
  • DigorDiePerformance's Avatar Topic Author
6 years 7 months ago #38328 by DigorDiePerformance
2003 F150 4.6 VIN 6 bank 1 sensor 1 pegged rich was created by DigorDiePerformance
Bank 1 sensor 1 o2 sensor is pegged rich
I checked for a vacuum leak with with brake cleaner
I smoke tested the intake
I checked the fuel pressure it was within spec
I checked for leaking injectors on bank 1(cylinder 1 had a old o-ring wedge in the rail but wasn't a issue)
I did a compression in cylinder 1 test(met spec)
I swapped bank 1 sensor 1 o2 sensor with bank 2 sensor 1(no change)
I created a vacuum leak to see if bank 1 would go lean(it did so that means the o2 is working
I put propane in the in the intake tract(Both o2 sensors with rich)
I did notice there's a exhaust leak on bank 1. I don't think it causing the issue.
I did a cylinder contribution test and notice when I load engine cylinder 1 and 3 would go negative(that means the aren't contributing the same as the other cylinders. I swapped cylinder 1 with cylinder 2. The issue went to cylinder 2. Then I moved it to cylinder 6 on bank 2. The issue moved to cylinder 6. But bank 1 o2 stayed pegged rich.
At idle all cylinders are 0
There is a noticable misfire but the misfire monitor is not counting any misfires.
6 years 7 months ago #38329 by John Curtis
Replied by John Curtis on topic 2003 F150 4.6 VIN 6 bank 1 sensor 1 pegged rich
Is one bank rich and the other lean (and is there any performance issue)?
What is your downstream reading?
Thinking you might want to test for a back pressure problem.
6 years 7 months ago - 6 years 7 months ago #38342 by DigorDiePerformance
Replied by DigorDiePerformance on topic 2003 F150 4.6 VIN 6 bank 1 sensor 1 pegged rich
When I first check the fuel trims. Bank 1 was rich and bank 2 was lean
I reset the keep alive memory. Bank 1 instantly starts pulling fuel out. Then the system starta just using bank 2 fuel trims
Bank 1 sensor 2 is also rich
I pulled the bank 2 rear 02 sensor but not bank 1 to check for a clogged cat
Last edit: 6 years 7 months ago by DigorDiePerformance.
