Cruise Control
  • Loney911
  • Loney911's Avatar Topic Author
6 years 7 months ago #38147 by Loney911
Cruise Control was created by Loney911
Suzuki Swift 2017
Symptoms
1.yellow triangle icon popup from dashboard
2. Few days later Cruise Control popup from dashboard
And here is DTCs >RBS(Radar Brake Support) C1618 > Sensor Misaligned
BCM B1104 > Luggage Antenna Circuit Malfunctions
BCM B150A Sunload Sensor Circuit High
I want tackle these DTC
Thanks
  • chief eaglebear
  • chief eaglebear's Avatar
6 years 7 months ago - 6 years 7 months ago #38162 by chief eaglebear
Replied by chief eaglebear on topic Cruise Control
What is a Sunload sensor ????
Last edit: 6 years 7 months ago by chief eaglebear.
  • chief eaglebear
6 years 7 months ago #38163 by chief eaglebear
Maybe somehow the radar brake support is also used by CC and the proximity sense is a cruise control function or something I don't know what I'm talking about that wish I had the schematic of circuit and maybe a module diagram I need to ask is your CC still operative and does your sensor still buzz
6 years 7 months ago - 6 years 7 months ago #38165 by John Curtis
Replied by John Curtis on topic Cruise Control
Sunload sensors are used for MVAC climate control. I can’t pull any diagrams for this vehicle, but for the sunload sensor it uses sunlight to determine how much resistance it will provide. It will be a 5V ref and the more sunlight (more resistance) it will lower the voltage. Using this logic, you can use something to cover the sensor to block the light and test it for voltage. See if once it’s covered if the voltage moves up closer to 5V.
Last edit: 6 years 7 months ago by John Curtis.
The following user(s) said Thank You: Noah, Loney911
  • Loney911
6 years 7 months ago #38170 by Loney911
Replied by Loney911 on topic Cruise Control
No idea it show on diagnostic tool
  • Loney911
6 years 7 months ago #38171 by Loney911
John Curtis wrote: Sunload sensors are used for MVAC climate control. I can’t pull any diagrams for this vehicle, but for the sunload sensor it uses sunlight to determine how much resistance it will provide. It will be a 5V ref and the more sunlight (more resistance) it will lower the voltage. Using this logic, you can use something to cover the sensor to block the light and test it for voltage. See if once it’s covered if the voltage moves up closer to 5V.
Ok will check but main concern is cruise control and want tackle the issue. here is dashboard indicator, if there are no issue main screen illuminate in white color
6 years 7 months ago #38221 by Tutti57
Replied by Tutti57 on topic Re:Cruise Control
Some vehicles always have the sunload sensor code, especially if scanned not in sunlight. I would ignore that one.
If your car is anything like Nissan's ADAS, your distance sensor may be out of adjustment. That's what the code sounds like to me. That could disable your cruise too. The sensor has to be dead nuts straight, like aligned using a target board and scan tool or else it will not work properly.
Does it still have warranty? Not many aftermarket shops seem to have gotten into that type of work yet.
Nissan Technician
The following user(s) said Thank You: Noah, chief eaglebear, Loney911
  • Loney911
6 years 2 months ago #41903 by Loney911
Replied by Loney911 on topic Re:Cruise Control
How can I solve this DTCs
C1618 sensor misaligned
After couple days this DTC is shown( C1690 sensor not aligned and I have data streamed screen shots
Thank you in advance
(This is same car posted on 8th March 2020)
6 years 2 months ago #41974 by Hardtopdr2
Replied by Hardtopdr2 on topic Re:Cruise Control
If there is a issue with the abs to where a code is generated it will dissable cruise control. So you will need to fix the brake system issue.
  • Loney911
6 years 2 months ago #41981 by Loney911
Hardtopdr2 wrote: If there is a issue with the abs to where a code is generated it will dissable cruise control. So you will need to fix the brake system issue.
So do I need to replace break shoes or break fluid??
Didn’t notice any issues in ABS and Break.
6 years 2 months ago #41986 by Hardtopdr2
You need to have RBS & MFL sensors aligned once that is done your cruise control should work.
The following user(s) said Thank You: nyradprescott1144.prescott
Time to create page: 0.413 seconds
