AC System Repair for 2002 Ford Focus Zetec 2.0L SE Wagon
  • dazs
  • dazs's Avatar Topic Author
6 years 7 months ago - 6 years 7 months ago #38043 by dazs
AC System was not been used for 2 years
What I assumed happened was the AC Compressor was bad because the clutch stop working. I replaced the AC Compressor 2 years ago and run fine untill it stopped.
What I did:
-Got a Ford AC compressor from the junkyard tested it with a 12V Battery and Multimeter (result) Clutch engaged and has 4.3 ohms
-New accumulator/drier
-used ac hose assembly
-I did a AC Flush
After everything installed with 7 oz PAG 46 oil to the AC Compressor time to recharge
1 hour evacuate the system with Vac pump and system has "No" leak
26 oz of 134a refrigerant
What happened:
Car is running AC "ON" FAN Full @4
Using my AC Manifold Gauge set the Low side and High side both started as "0" PSI
Applying refrigerant at the "Low side"
Low side gauge goes to 60 PSI
Hight side still "0"
The clutch never engaged even after the second can of refrigerant.
after applying refrigerant the Low side gauge that was 60 PSI went down to "0" again.
I lost all refrigerant in less than 10 seconds.
My Observation:
The Accumulator/drier is Ice Cold
I tried to evacuate the refrigerant using the gauge set "No Refrigerant"
and I assumed the system has no leak because evacuating the system maintained a 30 inhg vac @Low side guage for 1 hour
Hey guys...What could be the problem?
How did the Refrigerant escape from the system
FYI :
The new AC Manifold Gauge Set was used 1 time only 2 years ago and the recharge was successful without problems.
This is 2nd time using this gauge set.
also I try to make sure that I follow the proper steps using the gauge set in regards to opening the knobs in the ports...
Last edit: 6 years 7 months ago by dazs.
  • dazs
6 years 7 months ago #38202 by dazs
UPDATE!
The AC issue is resolved!
Symptoms leads to...
1. Possible accumulator/drier clogged or diffective which maybe preventing the refrigerant to go through.
2. Possible AC Low pressure switch not working
What I did
Did a test to see if the AC compressor would engaged by "overriding the low pressure switch"
-Remove the switch and from the connector harness put a paper clip across the 2 contact point.
-This will override the use of the switch and will activate the AC clutch when you turn on the AC from the inside of the car.
-Clearly the AC compressor works
so a new AC pressure switch maybe the solution
Regarding losing my refrigerant or it just disappeared after recharging.
My solution
I got a new accumulator from a different auto parts store
Result:
New AC switch and accumulator/drier did the trick!
Now I got a cold AC
Thanks for reading!
