2015 VW PASSAT CRANKING BUT NOT STARTING
  • alisabna
  • alisabna's Avatar Topic Author
6 years 8 months ago #37871 by alisabna
I HAVE 2015 MODEL VW PASSAT, DTC RETRIEVE 01314, CARRIED OUT ALL THE BASIC TEST, PCM POWER & GROUND FOUND GOOD.
NO REF VOLTAGE, KINDLY ADVISE IF ANY SIMILAR CASE HAS DUPLICATED??.
6 years 8 months ago #37878 by John Curtis
Replied by John Curtis on topic 2015 VW PASSAT CRANKING BUT NOT STARTING
No reference voltage could be either the engine computer, an open (depending where you’re testing) or something is shorted and pulling it down.
You can try unplugging sensors 1 by 1 while monitoring the voltage to see if it comes back.
The following user(s) said Thank You: Andy.MacFadyen, aboudi.naddaf
6 years 8 months ago #37896 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2015 VW PASSAT CRANKING BUT NOT STARTING
Unplugging sensors combined with visual exam is definitely way to go.
