How to test neutral switch grand cherokee laredo 2001 4.0l
  • rejeanlor
  • rejeanlor's Avatar Topic Author
6 years 8 months ago - 6 years 8 months ago #37508 by rejeanlor
Do I test my neutral switch from the starter relay or from the tcm relay with my test light attached to the positive side of the batteray should the light go when in gear and can I start the truck if I put the key in on position push the brakes and put it in neutral
Last edit: 6 years 8 months ago by rejeanlor. Reason: missed a question
6 years 8 months ago #37509 by jreardon
From the starter relay, #86 female terminal should get grounded if it's in park or neutral
For identifying relay terminals see
Code:
https://www.youtube.com/watch?v=sq0HLREinNU&feature=youtu.be&t=1825
  • rejeanlor
6 years 8 months ago #37510 by rejeanlor
If the neutral switch is bad should I be able to start it in neutral
6 years 8 months ago - 6 years 8 months ago #37513 by jreardon
Maybe, maybe not, try fiddling with the shifter and see if the shifter needs to be in the sweet spot for car to crank or not.
Install test light connected to battery positive and other end connected to #86 of starter relay (relay removed) and fiddle with going to park and neutral and see if you get the test light to light up.
Last edit: 6 years 8 months ago by jreardon.
6 years 8 months ago #37514 by Tutti57
What are your symptoms? You could test the switch by bypassing it. Go from pin two at the switch to a ground with your test light while trying to start the vehicle. That switch is just providing a ground when in P or N.
Nissan Technician
  • rejeanlor
6 years 8 months ago #37524 by rejeanlor
I've got no crank no start when I try to crank .are you talking about the neutral switch, and put the test light on pin two which would be the center one right
  • rejeanlor
6 years 8 months ago #37525 by rejeanlor
Hi, I did try to test on pin 86 the light stays on wathever in park or gear
6 years 8 months ago #37526 by jreardon
rejeanlor wrote: Hi, I did try to test on pin 86 the light stays on wathever in park or gear
Does the light ever go out?
If not. then #86 is grounded all the time then that's not your no crank problem. It is a problem but it's not your no crank problem.
Do you have power coming in at female terminal #85 at starter relay when you're in the crank position?
6 years 8 months ago - 6 years 8 months ago #37540 by Patrickreaves
Does it ever start at all?
ive seen more of these jeeps that had anti theft issues, than any other make and models , which it wont start, if thats the case.
Has anti theft been ruled out?
Last edit: 6 years 8 months ago by Patrickreaves.
  • rejeanlor
6 years 8 months ago #37589 by rejeanlor
Hi sorry I didn'T replied earlier the jeep starts when I go directly to the starter bendix
6 years 8 months ago #37591 by Tutti57
You should not have power at 86 in the crank position. The relay coil should act as a load and drop the voltage to near zero there. I believe you have an open somewhere after 86.
When you touched your test light there, in the crank position, it should have grounded that circuit though, unless you are using an LED test light?
Nissan Technician
