2006 Explorer EB 4.0L PCM ECT
- Msober1
- There’s a ass for every seat.
- Thank you received: 4
6 years 8 months ago - 6 years 8 months ago #37459
by Msober1
2006 Explorer EB 4.0L PCM ECT was created by Msober1
I have posted this problem before. I finally caught this problem on my scanner and it’s one of those intermittent ones. When engine is cold below 40* the startup rpm would go as high as 2600 or 2800rpm. No codes at all no pending codes and everything looked good but I tested all cold start system’s and removed and cleaned TB. Then one morning it was 5* outside and I plugged in my Snap On scanner and there it was-40 ECT. Turned on the key and in 2 or 3 seconds it would change but was still reading low. It’s a new sensor so I grab another one do a wiggle test again then plug in the newer one and it’s the same. Scanner saying I have 5v ref but I meter it and it’s true. So I tested the yellow sig return wire for high resistance from PCM to ECT connection and it’s good. It happens so fast that it sets the idle speed but will not set a code. So PCM is going out for R&R. Has anyone else ever had this problem????? Ty all who have replied along this nightmare because this truck is mine. Ha ha
Last edit: 6 years 8 months ago by Msober1.
- tech25
- Thank you received: 27
6 years 8 months ago #37461
by tech25
Replied by tech25 on topic 2006 Explorer EB 4.0L PCM ECT
never seen this problem before,, but if you have swapped known good ect parts multiple times, and you are POSITIVE both wires going to the ecm, and connectors and pins are also good.
then it has to be a faulty ecm.
but to be sure, with the scan tool hooked up, and reading the ect pid, and you unplug the connector, it should go to -40.. does it do that??
- TheTechWhisperer
- Thank you received: 47
6 years 8 months ago #37484
by TheTechWhisperer
"You will always find the greatest fulfillment in life when you are operating in the gifts God gave you"- Dad
National Director of Technical Training & Mechanical Operations - Express Oil Change & Tire Engineers
ASE Master L1 Tech
BMW Master Tech
Ford FACT Advanced Electronics Instructor
Replied by TheTechWhisperer on topic 2006 Explorer EB 4.0L PCM ECT
There is a software update for the PCM specifically for this issue. Check out TSB#07-23-12
ASE Master L1 Tech
BMW Master Tech
- tech25
6 years 8 months ago - 6 years 8 months ago #37485
by tech25
that tsb is superseded by # 08-18-02. it does not state anything about coolant temp sensor failure, and talks about throttle bodies issues. is there something you know that is not posted in the tsb??
TheTechWhisperer wrote: There is a software update for the PCM specifically for this issue. Check out TSB#07-23-12
Last edit: 6 years 8 months ago by tech25.
- Msober1
6 years 8 months ago #37494
by Msober1
Replied by Msober1 on topic 2006 Explorer EB 4.0L PCM ECT
Ty Tech25 for the reply. Yes I was sooo hoping it was the ect connector or hi res in harness to pcm but know luck.
- jreardon
- Thank you received: 198
6 years 8 months ago #37499
by jreardon
Replied by jreardon on topic 2006 Explorer EB 4.0L PCM ECT
Check pin fitment at PCM harness? If that doesn't fix it then back probe the yellow wire at the PCM and ground it out. If the PCM still show -40* then it's bad.
imgur.com/a/IZ5TULr
imgur.com/a/IZ5TULr
- Msober1
6 years 8 months ago #37580
by Msober1
Hey I want to say ty to all that helped with my truck. I performed all the tests and reperformed them and it’s all pointing to PCM. Ty so much for all the support
- Msober1
6 years 8 months ago #37581
by Msober1
Now I have a question for you guys about luck with reman PCMs. I would love to just go to ford and buy one but that’s out of my budget. What other companies have you worked with on Ford PCMs and have had good experience.
Time to create page: 0.362 seconds
