2003 Ford Escape Overheating
  • JIMMY2142
  • JIMMY2142's Avatar Topic Author
6 years 8 months ago #37226 by JIMMY2142
2003 Ford Escape Overheating was created by JIMMY2142
Hey guys,
i have a little bit of a problem with my ford escape 2003 2.0 Liter Xls
my fan won`t come on and it wil overheat, the gauge in my cluster will still read normale temp.
when i unplug my temp sensor the fan will go on at max
when i measure voltage its shows 5v when unplugt
and 4v when its cold en it will lower when it warms up, so i really dont no what the problem is at this point
sorry if my spelling is a little sh*t i did my best.(i`m Dutch)
Love to hear from you guys
6 years 8 months ago #37229 by Desmond6004
Replied by Desmond6004 on topic 2003 Ford Escape Overheating
How do you know it is overheating then?
6 years 8 months ago #37237 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2003 Ford Escape Overheating
Temperature gauge on dash on modern cars is a total work of fiction it tells you what the cars computers want you to see Often they will remain on N between 65 and 115c which is alarmingly high by old school standards and it is normal when the sensor unplugged for the gauge to sit on N and the fan to run.
Istr on Ford's the cooling fan low speed cut in temperature is about 105 to 108c
What exact symptoms are you getting ? I am thinking the cooling system isn't under pressure due to a failed pressure cap or pin hole leak
The following user(s) said Thank You: JIMMY2142
  • JIMMY2142
6 years 8 months ago #37252 by JIMMY2142
Replied by JIMMY2142 on topic 2003 Ford Escape Overheating
i know because its starts boiling out of the tank and the obd2 scanner says its 200c
6 years 8 months ago #37253 by Desmond6004
I wonder if the ECU has a bad ground - joining pins 4 and 5 at the obd plug would give it chassis earth. It may be worth a quick test while it's running but not when cranking the engine. Someone on another forum recently melted their scan tool lead because the scan tool plug automatically joins 4 and 5 and the engine had no earth so it used the scan tool cord.
6 years 8 months ago #37254 by Andy.MacFadyen
Can't be 200c and 200f isn't boiling. 200f is in the normal temperperature range of an engine and below expected fan switch on temperature.
Normal boiling point at atmospheric pressure as you find in a kettle is 100c that is 212f. In a radiator the anti-freeze solution is under presure so the boiling point running engine the coolant boils at over 120c that is 248f . If you take the presure cap off when the engine is hot but not hot enough for the computer to turn the fan on it will boil.
If the engine if forcing coolant out with the cap tightly on and the dash gauge on "N" and OBD2 reading 200c it could be a cylinder head gasket failure which there a test for but I would want to check the water circulation an.d pressure test the cooling stystem first
6 years 8 months ago #37255 by Andy.MacFadyen
6 years 8 months ago #37256 by Andy.MacFadyen
6 years 8 months ago - 6 years 8 months ago #37257 by Andy.MacFadyen
Normal boiling point at atmospheric pressure as you find in a kettle is 100c that is 212f. In a radiator the anti-freeze solution is under presure so the boiling point running engine the coolant boils at over 120c that is 248f . If you take the presure cap off when the engine is hot but not hot enough for the computer to turn the fan on it will boil. That the pressure cap is working properly and the system is free from even minor leaks and holding pressure is really important.
If the engine if forcing coolant out with the cap tightly on and the dash gauge on "N" and OBD2 reading 200c it could be a cylinder head gasket failure which there is a chemical test for but I would want to check the water circulation and pressure test the cooling stystem first
Last edit: 6 years 8 months ago by Andy.MacFadyen.
6 years 8 months ago #37262 by Chad
Replied by Chad on topic 2003 Ford Escape Overheating
Cooling fan Diagram
File Attachment:
File Name: 2003escape...fans.pdf
File Size:273 KB
6 years 8 months ago #37275 by Andy.MacFadyen
It looks to me like a coolant circulation issue or a headgasket failure --- chemical test or gas analyser sniff test on the air space in the coolant expansion tank
  • JIMMY2142
6 years 8 months ago #37278 by JIMMY2142
Thank you both for your tips i`m going to try them both and if I know more i let you know
  • JIMMY2142
6 years 8 months ago #37280 by JIMMY2142
ok so i found the problem i have another escape from a friend and i switched cabs and i was monitoring the obd scanner and at 220F the fans will come on
i`ve noticed the problem when i jump started a car and the tank was overflowing so that made me concerned
i really appreciated the help and i`m glad it was just a simple cap
(but if feel pretty stupid about this little thing)
