12 ford fiesta weird issue
  • bandrauto
  • bandrauto's Avatar Topic Author
6 years 8 months ago #37033 by bandrauto
12 ford fiesta weird issue was created by bandrauto
ive got a 12 ford fiesta thats got a weird issue and the only code that comes up is p0335 but that isn't related to the issue.
once the motor gets good and warm, you can go to accelerate and then it jerks like someone cuts the power, a couple lights come on in the instrument cluster, then it goes back to running, albeit, not as good, almost like in a partial limp mode, almost wont get out of its own way. i have checked almost everything i can think of on this one. i did a tsb i found for something similar and it still does it. ALMOST every time you go to accelerate. someone has been swapping parts to fix it before and i had a fiesta here i could verify good parts.
6 years 8 months ago - 6 years 8 months ago #37035 by Paul6004
Replied by Paul6004 on topic 12 ford fiesta weird issue
Leave it idling and move the engine harness by hand - also check engine earths and the main positive on the starter motor. It is most likely the twisting movement of the engine disturbing a bad connection.
Unless your cam timing is out.
Last edit: 6 years 8 months ago by Paul6004.
6 years 8 months ago #37041 by Cheryl
Replied by Cheryl on topic 12 ford fiesta weird issue
What have you swapped from the other fiesta to the problem one?
6 years 8 months ago #37042 by Cheryl
Wonder if you remove the abs and traction control fuse if the problem will go away. What scan data do you have to show us?
6 years 8 months ago #37044 by guafa
Replied by guafa on topic 12 ford fiesta weird issue
Hi guys,
Are always the same lights in the instrument cluster which come on?
Does it ONLY happend when engine is warm?
6 years 8 months ago #37090 by Matts Auto
Replied by Matts Auto on topic 12 ford fiesta weird issue
p0335 is a crankshaft position sensor A circuit fault. i would start testing at cps.
The following user(s) said Thank You: Noah, John Curtis
6 years 8 months ago #37091 by John Curtis
Replied by John Curtis on topic 12 ford fiesta weird issue
P0335 sounds like the code can absolutely be related to the symptoms you've listed. What makes you say it's not related?
It's very common for cam sensors to fail when they get hot and when the engine cools down will function until it's hot again.
Try cooling the Cam sensor if you don't have a scope to see what the sensor is doing.
