Hyundai wastegate
- Spiterijake
- Thank you received: 2
Car came into me with a low power complaint, found the turbo was in failsafe ( wastegate open ) pending code p2563 which is a wastegate actuator performance code. Cycle the key and power is retained, when road testing the car and driving it hard under high boost the car goes back into limp mode. I believe I have it narrowed down to the pcm but not 100% I'm seeing some weird and inconsistent pulsewidth from the pcm to command the wastegate actuator which leads me to believe it's the pcm. Any feedback is greatly appreciated or if anyone has ran into this before or has a known good waveform available. I want to be 100% and don't have access to a known good waveform.
Wastegate actuator was changed and is properly adjusted
Yellow trace is the signal from the ewga to the pcm
Green trace is pulsewidth for the motor from the pcm
1.2v is wastegate open and 4.2v is wastegate closed, the pcm is seeing the wastegate signal pass 4.2 and hit 4.9v multiple times within 5 seconds and flags the code therfor putting the turbo into failsafe. Does the green trace look normal? I've attached a wiring diagram as well
- derekoliveira
Sensors and components can make the engine get in limp mode!
- Spiterijake
- Cheryl
- Thank you received: 215
- Spiterijake
- derekoliveira
- Cheryl
- Spiterijake
- Spiterijake
Is that accurate, were you maybe moving the leads around or something?
- Spiterijake
- Fasfalcon
- Spiterijake
