Injector pulse
  • Ricksofla
  • Ricksofla's Avatar Topic Author
6 years 9 months ago #36565 by Ricksofla
Injector pulse was created by Ricksofla
Good morning, I have a 1995 suburban, 454. No spray from the injectors. I replaced the distributor, di module, ecm, plugs, wires, fuel pump. I'm getting fuel to the tbi and good spark. I have no it lights, test light and fluke meter. Can't figure it out! I'm an electrican not a tech.
6 years 9 months ago #36570 by Cheryl
Replied by Cheryl on topic Injector pulse
You have spark so the inputs must be good. Have you checked for injector pulse by unplugging an injector and putting a test light in place of an injector while cranking?? Maybe there clogged to if it’s been sitting awhile
6 years 9 months ago - 6 years 9 months ago #36571 by Chad
Replied by Chad on topic Injector pulse
KOEO, do you have battery voltage on ALL 4 injector wires, (two pink wires, Blue, and Green)? (connectors connected) If not, check ECM-1 (20 amp) fuse.
Last edit: 6 years 9 months ago by Chad.
  • Ricksofla
6 years 9 months ago #36690 by Ricksofla
Replied by Ricksofla on topic Injector pulse
Yep, plugged a noid light in, nothing. Connected a test light to the positive term on the battery and touched it to the purple/wht wire on the 4 wire plug on the di module and the light flashed. (2nd module)
  • Ricksofla
6 years 9 months ago #36691 by Ricksofla
I'll check when I get home from work and let you know. Thanks
6 years 9 months ago #36725 by guafa
Replied by guafa on topic Injector pulse
Hi Rick/everyone.
Di module sends a 5 volt pulse to ecm. So you have verified that ecm is receiving pulse from di module and injectors are receiving ecm shooting signal, because light (connected to injector connector) is flashing.
I suggest you a 5 volt pulse (instead of 12 volts) in case you need to test again.
I would check injector/s spray, by feeding 12v in one of the pin injectors (could be any of them) and touching the other to ground.
Warning!!! Do not activate injectors for more than 1/2 seconds. Those are pick and hold injectors and they consume something like 14 amps.
  • Ricksofla
6 years 9 months ago #36755 by Ricksofla
Thanks everyone, it was a blown ecm fuse!
6 years 9 months ago #36766 by Cheryl
What blew the fuse??
  • Ricksofla
6 years 9 months ago #36800 by Ricksofla
Don't know but it starts up every time now!
