code p0105
- ronald316
- Thank you received: 13
6 years 9 months ago #36556
by ronald316
code p0105 was created by ronald316
im working on this 2005 jeep liberty 2.8 diesel.i checked all the wiring for this code ground sense 5 volts all is good changed sensor.code comes back i checked inercooler with smoke machine hoses and intercooler is sealed holds vacuum checked intake tube no cracks.what am i missing.by the way it comes back under heavy acceleration
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
6 years 9 months ago #36557
by VegasJAK
Replied by VegasJAK on topic code p0105
MAP works in conjunction with the TPS (throttle position sensor)... if the code is setting at high load higher RPM the voltage is above 4.5v. Clean throttle plate and check the TPS.
- ronald316
6 years 9 months ago #36562
by ronald316
Replied by ronald316 on topic code p0105
thanks i will check today and report back
- ronald316
6 years 9 months ago #36588
by ronald316
all checks out i didi notice today smooth acceleration sets the code also.i wonder if i need to test intercooler and hoses with more pressure like 20 psi
- derekoliveira
6 years 9 months ago #36602
by derekoliveira
Replied by derekoliveira on topic code p0105
If egr is open or partially when engine is under load, it may set that dtc!
Block egr and delete dtc. Be aware it will set egr dtcs.
- ronald316
6 years 9 months ago #36908
by ronald316
i bought a turbo intercooler tester and i found the turbo hose from intercooler and turbo. i cant get the hose to seal .the rubber inside is all moshee and soft so i ordered a new hose will report back
