Cranking but No start... Can anybody help with this issue ?!!!
  • gearup.garage
  • gearup.garage's Avatar Topic Author
6 years 9 months ago - 6 years 9 months ago #36380 by gearup.garage
My Chevrolet Beat is cranking but not starting. I got four error codes, which are
P0087 - Low Rail Pressure
P062B - Control Module Fuel Injector Control Performance
P0113 - IAT Sensor Circuit High Voltage
P0101 - Mass Air Flow Sensor Performance
I had performance issues for month before going dead, wouldn't go beyond 50mph no matter how much I press the pedal.
As far as I have checked the rail pressure is low, not getting enough pressure from High pressure fuel pump, and also no power to the injector feed wire and earth wire.
Last edit: 6 years 9 months ago by gearup.garage.
  • gearup.garage
6 years 9 months ago #36381 by gearup.garage
Replied by gearup.garage on topic Cranking but No start
Chevrolet Beat 2011 Diesel
6 years 9 months ago #36387 by Crombie
Replied by Crombie on topic Cranking but No start
Not going over 50mph would be in limp mode, fail safe mode id imagine. Check that you have a 5 volt reference on the sensors, on a Ford Focus diesel over here in the U.K it was saying low fuel rail pressure, because the rail sensor was on the 5 volt reference, what it was actually a bad EGR valve, that also shut down the 5 volt reference circuit, I can't remember the reason why right now, but check to see if you have a 5 volt reference on a few sensors
6 years 9 months ago - 6 years 9 months ago #36389 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Cranking but No start
Non starts on disels are often due to low fuel rail pressure this can be due to excess I've leak back from an injector or pump fuel pressure r. egulatorIf the engine computer sees low fuel rail pressure below a minimal value I would think the engine computer won't even attempt to fire the injectors. As there is also a performance issue I would suspect the lack of fuel rail pressure is real rather than a faulty sensor or power & ground failure. I would start with an injector leak off test and electrical tests on the hp rail pressure sensor. I would also do cam and crank sensor checks. My feeling gut however is this is a fuel pressure regulator issue.
Last edit: 6 years 9 months ago by Andy.MacFadyen.
  • gearup.garage
6 years 9 months ago #36418 by gearup.garage
Thank you for the response will check and get back to you
  • gearup.garage
6 years 9 months ago #36461 by gearup.garage
I have checked the fuel pressure regulator, it works well.
  • gearup.garage
6 years 9 months ago #36462 by gearup.garage
There is 5V reference
  • gearup.garage
6 years 9 months ago #36464 by gearup.garage
I have attached some screenshots of the data streem readings, maybe it could give some Clue
  • gearup.garage
6 years 9 months ago #36465 by gearup.garage
Why is that desired rail pressure value is out of range ?
Time to create page: 0.391 seconds
