MAF Sensor
  • Hoof-Hearted Ewe
  • Hoof-Hearted Ewe's Avatar Topic Author
6 years 9 months ago #36359 by Hoof-Hearted Ewe
MAF Sensor was created by Hoof-Hearted Ewe
2002 Dodge Status R/T 3.0 Liter, manual transmission, K&N cold air intake system.
The current codes displayed are p0102 and p0421.
Low idle when cold (wants to stall), but good when warm, except shifting is not smooth.
If I jab the accelerator pedal, it's not properly responsive.
The car runs pretty well otherwise, although perhaps slight loss of power.
I suspect the MAF sensor to be the issue.
I've been searching unsuccessfully for substantial information regarding the cleaning of Karman Vortex sensors.  Apparently this type of sensor can be damaged by cleaning, although I've read that many have successfully cleaned theirs.
I suspect my 2002 Dodge Stratus R/T (Mitsubishi) has a Karman Vortex sensor, but am unable to determine for sure, and am therefore reluctant to try cleaning it without being certain that it is malfunctioning.
The prior owner installed a K&N cold air intake system, which I suspect to be contributing to sensor issues.
If anyone knowledgeable reads this, I would GREATLY appreciate any helpful feedback!
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
6 years 9 months ago - 6 years 9 months ago #36372 by VegasJAK
Replied by VegasJAK on topic MAF Sensor
check signal, power and ground... three wire maf. signal wire voltage is on-off 5v-0v(test with engine running). If no reading, KOEO unplug connector to maf, signal voltage should be 5v. If not 5v, you have a wiring problem. KOEO power wire is 5v. Ground should be no more than 0.1 volts.
K&N air filters are known to cause MAF problems.
Last edit: 6 years 9 months ago by VegasJAK.
6 years 9 months ago #36379 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic MAF Sensor
Before doing anything else the first thing is put the standard air intake and filter back on and check the mesh screen on the MAF sensor is in place. MAF sensors get thrown a curved ball if anything before the airflows into the MAF is changed. If the velocity profile is altered the MAF sensor will not be in the correct position or have the correct calibration to measure how much air is going into the engine.
  • Hoof-Hearted Ewe
6 years 9 months ago #36383 by Hoof-Hearted Ewe
Replied by Hoof-Hearted Ewe on topic MAF Sensor
Thank you very much for sharing your time and knowledge.
I will try this asap.
  • Hoof-Hearted Ewe
6 years 9 months ago #36384 by Hoof-Hearted Ewe
Thank you for taking the time to help me out.
...Looks like a trip to the junk yard may be in my future...
