Gauges dropping out
  • Henry Carey
  • Henry Carey's Avatar Topic Author
6 years 9 months ago - 6 years 9 months ago #36242 by Henry Carey
Gauges dropping out was created by Henry Carey
1996 Jeep Grand Cherokee Laredo gauges drop out when revving engine?
Last edit: 6 years 9 months ago by Henry Carey. Reason: changed to "drop out "
6 years 9 months ago #36244 by juergen.scholl
Replied by juergen.scholl on topic Gauges dropping out
1- These clusters used to fail because of cold solder points
2 - Check for excessive AC-voltage, also a common issue on these.
3 - make sure you don't loose the bus.
HTH
6 years 9 months ago - 6 years 9 months ago #36246 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Gauges dropping out
As above --- also rpm related issues are often new to opens where there is movement or loose bad grounds
check the shared grounds (its a Chrysler !) and harness where it runs engine to body or any where there is relative movement that could pull down or open the bus. I also would do a ressistance check between can high and can low wires should be 60 ohms
An oscilloscope makes this kind of issue easier to track down.
Last edit: 6 years 9 months ago by Andy.MacFadyen.
