Ground / Earth Issue- help
  • forumoto
  • Christ De KING
6 years 10 months ago #36064 by forumoto
Ground / Earth Issue- help was created by forumoto
I came across this issue twice on vw and volvo, and this two fault is happening to same
Sensor. O2 sensor, 4 wires. I notice that the earth or ground wire flashes or blinks, , for Volvo new oxygen was change yet still issue persist, same as the VW mk6, on the Volvo a used pcm was replaced to the original pcm, yet the problem still persist, and this issue ignite check light telling that the sensor is not working whereas they are new ans there is no short to ground or earth if you do continuity test on the line alone. What is common about this two cars is that, the get their earth from the pcm, power from fuse box, Yet this two cars ground blinks and complain that the sensor is not good. Even though sensors are oem, please need help as to whosoever has face this issue before. And how it was dealt with.
Thank
Christ De Way Maker
  • dfends@hotmail.com
  • dfends@hotmail.com's Avatar
6 years 10 months ago #36066 by dfends@hotmail.com
Replied by dfends@hotmail.com on topic Ground / Earth Issue- help
Did you check your power source for high resistance ?
The following user(s) said Thank You: forumoto, aboudi.naddaf
6 years 10 months ago #36067 by dfends@hotmail.com
voltage drop test?
  • forumoto
  • Christ De KING
6 years 10 months ago #36096 by forumoto
Replied by forumoto on topic Ground / Earth Issue- help
Voltage drop, I did not tested that,
But as I mentioned earlier the B+ voltage does not blink, it is only the ground that is being supplied by the board or pcm, is what flashes
Christ De Way Maker
6 years 10 months ago #36124 by Desmond6004
Replied by Desmond6004 on topic Ground / Earth Issue- help
forumoto wrote: I notice that the earth or ground wire flashes or blinks, ,, Yet this two cars ground blinks and complain that the sensor is not good.
How does the ground wire "blink"? Is it making sparks or something?
  • forumoto
  • Christ De KING
6 years 9 months ago #36174 by forumoto
Yes, it sparking , whenever the car is started , and you put test light to the earth wire that come from the pcm, you see it sparking, but when you ground or earth the tester to the car body and you check the positive side of the wire that comes from fuse side, no spark, so I am wondering why the ground or earth from
the board should be giving such flashing light or sparking light...
Christ De Way Maker
The following user(s) said Thank You: Desmond6004, aboudi.naddaf
6 years 9 months ago #36185 by juergen.scholl
Replied by juergen.scholl on topic Ground / Earth Issue- help
You may be seeing the pulse controlled heater ground on this 4 wire sensor:
There is a constant voltage feed to the O2 sensor heater circuit and this circuit ispulse controlled to ground by the ecm. When it is pulsed to ground there's no voltage on the control wire and your test light will not light. When it is not pulsed to ground then there will be open circuit voltage on the ground wire and your test light will light.
The heater wires are often times the same color helping to identify them....
To verify proper O2 sensor function check the signal wire with a scope or a multimeter .
The following user(s) said Thank You: Noah, Desmond6004, aboudi.naddaf
