2005 Jeep Grand Cherokee hot soak restart problem
  • Cheryl
  • Cheryl's Avatar Topic Author
6 years 10 months ago #35912 by Cheryl
Im having a fuel aeration issue I believe. Key on engine off fuel pressure gauge on schrader valve 58 psi. Then go to bleed fuel pressure off with gauge it has tons of air in it. I can fill up half a Mountain Dew 20 oz bottle key off. Bleed hose on fuel gauge submerged in fuel looks like your blowing in a straw in water. Checked fuel lines for missing heat shielding. Checked rail temp 189 degrees with infrared thermometer. Anyone see this issue before??
6 years 10 months ago #35914 by gav09
Which engine is it?
6 years 10 months ago #35915 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2005 Jeep Grand Cherokee hot soak restart problem
Heat soak produces fuel vapour rather than air I wonder if you have an issue on the suction side of the fuel pump
  • Cheryl
6 years 10 months ago #35919 by Cheryl
3.7
  • Cheryl
6 years 10 months ago #35920 by Cheryl
I installed clear hose between between fuel rail and engine feed line it didn’t look like it had air in it when running. But anything is possible
