06 honda ridgeline 3.5L melted cats.
- gilbert
- Thank you received: 15
6 years 10 months ago #35884
by gilbert
06 honda ridgeline 3.5L melted cats. was created by gilbert
God bless you my brothers and sisters.
Hey I have a quick question I have this ridgeline with melted cats. I removed all the crap from pipes question is will this cause misfire on all cylinders?
Thank you.
Thank you.
- John Curtis
- Thank you received: 111
6 years 10 months ago #35885
by John Curtis
Replied by John Curtis on topic 06 honda ridgeline 3.5L melted cats.
It can absolutely cause a misfire do to breathability.
It can cause internal damage to an engine if it goes unfixed.
A misfire can also cause a melted CAT. You’re going to want to figure out what killed the CAT and address it before the replacement gets damaged.
Other things to consider would be damage to the valve-train, crankshaft and bearings and piston rings.
The following user(s) said Thank You: gilbert
- gilbert
6 years 10 months ago #35886
by gilbert
Replied by gilbert on topic 06 honda ridgeline 3.5L melted cats.
Ok let me give you some history on this truck I replaced the engine on it because the timing belt jumped. Customer didn't want to fix the old engine. Upon removing the exhaust I seen one cat melted and the other one already dissolving "melting" I let the customer know . Installed the junk yard engine and it ran good . I'm in Ti Juana Mexico and the customer took it to LA Cali. two time with no problems on the third time the other cat.melted and plugged the exhaust. This is were I'm at now I cleaned all that was melted so it has no obstruction in the pipes so my question is with straight pipes will it cause a all cylinder misfire? I don't know if the truck was misfiring before the melted cat will have to ask customer.
Thank you.
Thank you.
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
6 years 10 months ago #35887
by VegasJAK
Replied by VegasJAK on topic 06 honda ridgeline 3.5L melted cats.
If you remove the rear 02's as well as the cats, the front 02's can run the engine without problems unless the engine has other mechanical or sensor related problems. You will get rear 02 and cat codes.
- gilbert
6 years 10 months ago #35888
by gilbert
Scannerjohn both bank 1 and 2 are empty. The third cat is still on and all 4 o2 sensors. Customer tells me there was no misfires before. Do u think if I disconnect the o2s the misfire will go away.
- Cheryl
- Thank you received: 215
6 years 10 months ago #35889
by Cheryl
Replied by Cheryl on topic 06 honda ridgeline 3.5L melted cats.
So it’s misfiring now??
6 years 10 months ago #35890
Replied by Tyler on topic 06 honda ridgeline 3.5L melted cats.
Hey Gilbert! If your cats are empty, you should be good to go. As long as the customer can live with the CEL, anyway. :silly:
Do you still have a miss? I have seen plugged cats on this engine take out the lower end sealing ability.
Shows up on a relative compression and leak down test.
The following user(s) said Thank You: gilbert, John Curtis
- John Curtis
6 years 10 months ago #35891
by John Curtis
Without knowing the cause of the misfire, there’s no telling. However, removing the 02s should make the ECM use default values. The result will be worse gas mileage.
If the 02s are indeed the cause of the misfire, then it is fuel-control related and you should be able to see that with live scan data.
- gilbert
6 years 10 months ago - 6 years 10 months ago #35892
by gilbert
Cherly yes on all cylinders I have long cranks also. Going two check compression tomorrow I think the belt might of jumped.
Last edit: 6 years 10 months ago by gilbert.
- gilbert
6 years 10 months ago #35893
by gilbert
Hey Tyler I'm thinking this engine is shot. It is misfiring with a clean exhaust there is no more obstruction. I will check compression tomorrow to see what damage was done.
- gilbert
6 years 10 months ago #35937
by gilbert
Hey Tyler you are right again the plugged exhaust damaged the engine compression on cylinder 5 was 45 psi.
Thanks guys for your help.
6 years 10 months ago #35938
Sorry, sir.
Mine was exactly the same way - Low on #5, low-ish on #4 and 6. It's remarkable how quickly the damage occurs on these engines.
I'll try to dig up a pressure pulse sensor waveform I took off mine. Connected to the crankcase, saw three clear pulses every 720 degrees. :silly:
