1995 Mitsubishi Eclipse
  • rudolph.palm
  • rudolph.palm's Avatar Topic Author
  • Dont Limit Your Challenges, Challenge your Limits!
6 years 10 months ago #35776 by rudolph.palm
1995 Mitsubishi Eclipse was created by rudolph.palm
Hello, I am working on a 1995 mitsubishi Exlipse. Main complain is idle fluctuation, Intermitted Non throttle response, stalls several times before stay idling but surging idle badly. DTC code for IAC motor problem. Customer put a new idle control motor without any fix. Car runs but poorly.
My scan tool does not communicate with the ECU in OEM mode. Only OBD standard. Looking for some live data I can see, Minus 40 degree on ECT sensor, Minus 40 degree for IAT sensor. Error code for MAP as well. This engine is a MAP engine, NO Mass Air Flow sensor. Both Sensors are OK. Wiring are OK to the sensors. Ref voltage 5 volts and grounds present on each sensors. So far I have troubleshooted, everything point out on a bad ECM. Any suggestion will be appreciated...
6 years 10 months ago #35778 by John Curtis
Replied by John Curtis on topic 1995 Mitsubishi Eclipse
What codes are you getting? I would save the scan or write down the codes and try to clear the codes to see what happens.
Then pick one code maybe MAP in this case (whatever is easiest to get to) and check it against code set criteria. If everything checks out and fails to meet the code set criteria then it’s bad PCM. If you don’t have access to code criteria I will send it to you along with diag charts.
The following user(s) said Thank You: rudolph.palm
  • rudolph.palm
6 years 9 months ago #36250 by rudolph.palm
Replied by rudolph.palm on topic 1995 Mitsubishi Eclipse
Hi, The problem was fixed by replacing the ECU.
6 years 9 months ago #36269 by Noah
Replied by Noah on topic 1995 Mitsubishi Eclipse
Thank you for updating us with a fix.
Curious, did you notice if the temperature pids are accurate now?
  • rudolph.palm
6 years 8 months ago #37531 by rudolph.palm
Yess, the temp reading for the Engine Coolant and Intake Air was reading accurate after replacing the ECU.
6 years 8 months ago #37537 by Patrickreaves
Replied by Patrickreaves on topic 1995 Mitsubishi Eclipse
nice
