92 saturn running rich ???????
- keith.dennis
6 years 10 months ago #35732
by keith.dennis
92 saturn running rich ??????? was created by keith.dennis
we have a 92 saturn sl2 dohc in the shop it came in on tow with a bad engine we replaced the engine with a used one 60k miles engine runs great except at about 1500-1700rpm. If you hit the accelerator fairly quickly it revs up fine but if you ease into the throttle its fine before and after this specific rpm range of 15-1700. integrator at idle is 128 and block learn is 108 , while the throttle is pressed at 15-1700 integrator drops down to 70-65 and the engine obviously runs rough. the throttle position sensor , IAC have been replaced . we did find the ECT sensor and pig tail where causing a problem before we performed a wiggle test on the pigtail and the temp would fluctuate so we replaced those. the map sensor had carbon built up in the port so we replaced it aswell its progressively gotten better but we still have this issue at 1500. We have a triton d8 scanner with 2 channel scope but we arent proficient in using it that is why we have joined this program we did scope the map sensor signal and the wave form would spike .5v to around 1.5v at idle and when it was acting up it would spike up to around 2.5v . any tips would be great thank you in advance
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
6 years 10 months ago - 6 years 10 months ago #35738
by VegasJAK
Replied by VegasJAK on topic 92 saturn running rich ???????
for integrator readings... 128 = 0
below 128 is lean, above is rich.
your block 108 is approx. -10 LTFT.
when you increase the rpm to 1500 your going extremely lean, approx -42.
check your fuel pressure readings.
.5 to 1.5v MAP at idle is Ok.
Last edit: 6 years 10 months ago by VegasJAK.
- Cheryl
- Thank you received: 215
6 years 10 months ago #35739
by Cheryl
Replied by Cheryl on topic 92 saturn running rich ???????
What are the oxygen sensors reading? Are they accurate?? See if they respond to rich and lean conditions
- Cheryl
6 years 10 months ago #35740
by Cheryl
1500-1700ish rpm almost sounds like an rpm that the purge valve would open. Maybe it’s sticking if it has one being that old I can’t remember. If it has one I’d cap off the line and retest.
- Matts Auto
- Thank you received: 28
6 years 10 months ago #35743
by Matts Auto
Replied by Matts Auto on topic 92 saturn running rich ???????
What's fuel pressure reading at idle & 1500 rpm with load
Time to create page: 0.346 seconds
