no start
  • markg123
  • markg123's Avatar Topic Author
6 years 10 months ago #35703 by markg123
no start was created by markg123
2002 Nissan pathfinder 3.5 l 4x4 alternator sometimes not charging changed alternator with used one same problem pulled neg battery cable engine died charged battery started engine pulled neg cable engine did not die not sure if computer turns alternator on or bad charge wire to battery maybe bad ground were to start may be bad alternator repair shop did a test said alternator work fine
6 years 10 months ago #35712 by Tutti57
Replied by Tutti57 on topic Re:no start
You can try doing a voltage drop test on your alternator cables, to make sure everything is connected well. Also make sure the drive belt is tight enough and not slipping.
Nissan Technician
