Can issues , power seats, radio
  • Jmihalchik
  • Jmihalchik's Avatar Topic Author
6 years 10 months ago - 6 years 10 months ago #35548 by Jmihalchik
Can issues , power seats, radio was created by Jmihalchik
Hello all. Need a little guidance. Working on a 2012 Mercedes C250. Customer had a prior shop replaced the EIS, stating that was the issue causing the no start, random start up stall out once moved. After no fixi got the car, Customer had water infiltrate the vehicle and submerged a star connector on the power train can bus. Under the passenger floor board, Once I removed the water and replaced the connector, car started and ran with no issues. Not thinking to check the seats , customer comes to get car and can’t move the seats. Radio also does not work which they did not have a concern about.
I have checked power and grounds on the seat module and the radio and all is well. Radio will blip on if I communicate with the scan tool, but only for 1/2 a second. Both the radio and the seat module have a P061000 code (attached). I scoped the interior can bus and all seems alive and well with the signal (in link in reply). Do you think this is just a programming issue of the replacement EIS?
Last edit: 6 years 10 months ago by Jmihalchik.
  • Jmihalchik
6 years 10 months ago #35549 by Jmihalchik
6 years 10 months ago #35550 by Cheryl
Replied by Cheryl on topic Can issues , power seats, radio
I’d agree with you it’s a coding issue. Any coding can be done with the scanner you have?? Probably dealer only
