Nissan e4wd
  • Caritech
  • Caritech's Avatar Topic Author
9 years 9 months ago - 9 years 9 months ago #4689 by Caritech
Nissan e4wd was created by Caritech
Anyone familiar with Nissan's e4wd systems?
The system consists of a rear motor for driving rear wheels, engine driven generator for powering the rear motor, cand a control module.
The issue is the 4wd system isn't working. Initially the generator seemed not to be putting out power to the motor. Think of it like an alternator; output terminal and 2 pin plug. One wire comes from a relay and with switch on 4wd engine running is showing battery voltage but the other got no higher than 59mv. The output of the generator was 3v but if I put my test light to battery +ve and touch the low voltage wire the generator comes on producing system voltage 14-19v.
My thoughts are the module should be good because I think it's what's activating the relay when 4wd switch is pushed. One thing I do find strange is the switch has 6 wires ; 12v, 3 grounds, 5v, and one that seems dead, when you push 4wd 12v stays, 5v is grounded, and the "dead" wire is grounded. I find it strange because it goes from 3mv to gnd, suspected open.
Last edit: 9 years 9 months ago by Caritech.
9 years 9 months ago #4694 by 93Rubie
Replied by 93Rubie on topic Nissan e4wd
You must be in another country as Nissan does NOT use this system in USA. Do you have access to aftermarket information like Mitchell's or Alldata?
9 years 9 months ago #4698 by Noah
Replied by Noah on topic Nissan e4wd
Glad it's not just me, I haven't run into that design on a Nissan.
If you post the year, make and model, we might be able to gather some service info.
Any trouble codes?
  • Caritech
9 years 9 months ago #4702 by Caritech
Replied by Caritech on topic Nissan e4wd
Was hoping to get lucky but Nissan didn't use it in the US and no aftermarket info so I have to figure it out as I go. From Trinidad and Tobago.
