Subaru Impreza 2003
- scotty.sutherland
- Thank you received: 2
I have a 2003 subaru impreza wrx only has induction kit everything else is standard/stock it was recently rebuilt with closed deck shortblock, been having problems main one being the car will not idle with maf in... just idle hunts so low it stalls, but will run and idle fine with maf out, i tried a diff maf (wasnt new) and it did the exact same thing? Replaced intake manifold gaskets and checked for leaks did compression test, checked coils/plug gaps etc, there is also no error codes wen its idling low/stalling.
The other weird problem is my head unit is toast as its getting power and solid ground, But.... the rear of my car chassis is not grounded so my amps couldnt possibly work now as there grounded in boot!? but the front of chassis is showing ground lol the ground thing sounds impossible to me lol makes me think somethings bad with wiring/ground and its all related
Any help would be great!
Sometimes those "power adders" are problem makers.
- scotty.sutherland
- scotty.sutherland
- scotty.sutherland
(Minus the fan code)
- scotty.sutherland
** engine was warm when i put the stock filter bk on, not sure if tht makes a diff
- Cheryl
- Thank you received: 215
- scotty.sutherland
- scotty.sutherland
but idle is dropping loow after i clutch etc then goes bk up n idles nice , tripped a p1444 evap code (ive had evap etc off n checked it today so i figured thts wat caused tht code) cleaned iacv few days ago so tht is clean and spins smooth, ive had an idle issue like tht b4 but cant remember wat caused it :S Please Log in or Create an account to join the conversation.
Do you have a scanner that will show iac counter?
I might try cleaning the throttle body and then resetting the PCM, then idling and driving it to relearn.
Thinking you might just be at maximum idle air correction and there's just no room for the iac to increase air flow.
- scotty.sutherland
- scotty.sutherland
During that capture you were 50°c min, max & avg. So it never changed during the capture which doesn't necessarily indicate a problem depending on how long it was running and how long you were logging.
(50°C × 9/5) + 32 = 122°F. Thanks Google
If you can make a custom data list I would include:
Engine RPM, Desired RPM, IAC position, ECT, IAT, whatever throttle position data you have and engine run time (if available) and watch it warm up a little from a cold start without giving it any throttle.
- scotty.sutherland
- scotty.sutherland
**thanks mr paul danner for sending me to the forum**
